Guest Posted April 22, 2011 Posted April 22, 2011 Pickes one up today and will be fitting it tmrw, I will let you all know how it goes if it works etc, I now it has been a post before but that was in 2009 .It is being fitted to a black Kawasaki Z750S with carbon fibre(look) chain guard. I wil post some photos if I don't forget. They cost 129 euros here with oil and all the parts you need to fit it.Saturday.Ok in de the advertisement they reckons it takes 20 minutes to fit, I spent 20 minutes figuring out where to fit it, I decided in the end on the helmet lock had to tap another screw which fits nicely behind the lock.But once thats done its quite easy to do.And it works, they say you should fit it on the right hand side of your bike so you can ride away slowly to spread the oil but i decided that I would put it on the left because of the location of the brake cyclinder. locationThe nozzlepipe line Quote
