are tyre pressures lower when its cold?
as my tyre was at 34psi yesterday but this morning its cold and its 31psi
Guest philgale
yes, as they get hotter the pressure rises, not my much tho. was 34psi checked just after a ride?
Yes and you should always check your tires when cold also before you go out for a blast ;)
just checked what it should be so pumped up to 2.5 bar then just been out on a ride got home and it was 2.75 bar :P
it does change a lot with the heat!
Bex should be able to answer this one very well :lol:
PV/T = constant
If the temperature goes up & volume stays same then the pressure goes up 8-)
Anyway yeah, measure pressure when they're cold!
Also what's written on your tyre is usually the Max psi pressure,best reffer to your user manual for the recommended pressure.
I always tend to email the tire manufacturer for the recommded pressures as usually the manual are printed way before the bikes are produced. Most of the tyre manufactures whose tyres I've put on my bikes in the past are quite good and you get a reply fairly quickly.
I've even had one txt me the correct pressures in the past. That was dunlop.
