oil light staying on
Hi there everyone
My friend has got a zx6r 1996 F series and after being unused over the winter has gone to use it and the oil light is staying on when bike is running and also the oil doesn't move in the sight glass. I have to say it sounds a bit rattly on the top end. I have changed the oil and filter but the problem persists. Please please has anyone got any suggestions that I could try :D
Thanks everyone looking forward to your help!!!!!!!!!
:stupid: Its an oil pressure light. You have oil in the engine so for some other reason its not pumping it round at required pressure.
sounds like the oil pump is blocked or given up the top end will distroy itself if you keep runing it like this it need looking at without running it any more
