Hello everyone,
Long time, no post.
A lot of talk about MoT test regulations recently, so being a tester thought i would share this link with you :
http://www.transportoffice.gov.uk/crt/d ... guides.htm
It s all up to date and is what I work from when testing.
Just remember the MoT test is the bare minimum standards at the moment of test.
Hope this helps
Lucky
Thanks for the link. In the section for the exhaust, it does not make any mention of the cat convertor and emissions testing - is this a change or is it tested in a separate section?
At the moment cats and emissions aren't tested.
There is note about excessive smoke some where but don't worry about it.
I assume your going to or have fitted one, which exhaust system did you pick?
