hi, i have a cbr1100 97 and i was wondering if anyone knew whether the forks from an 07 blackbird would fit my bike?I have asked another site about this and someone disagrees but i have been told otherwise and was wondering what you knowledgeable folk have to say on the matter... they do look the same.. thanks in advance for any input, cheers.
you need to check the fork diameter and centre to centre meausrements across the top yoke or if you are planning on using the whole fron end including yokes forks mudguard wheel discs and brake calipers then you need to check stem size on bottom yoke for diamter and length where it passes through frame into top yoke
