shauneyboy Posted August 20, 2012 Posted August 20, 2012 Hi Guys Wondered if you could help me m y 11 plate derbi terra adventures chain as got a kink in it and as rusted on every pin even though it as a good covering of oil i have been told to exchange for a did aftermarket chain but do not know what length it is or what pitch the chain is and do i have to change the sprocket allso the bike as done approximateley 2000 milesany help greatfully receivedcheers Shaun Riley Quote
rushwind Posted August 20, 2012 Posted August 20, 2012 ay up shaun, you need either a 428HD-130 HD CHAIN or 428H(RJ) X 130, not to sure what the difference is , but both fit, i think 1 is a'gold', hm, if chain is worn, it will usually put more wear on the sprockets, and usually front sprockets will wear more rapidly asthey make more turns, so, take a look at the teeth on the sprockets, if any look at all hooked, then replace,,,,,front sprocket is only about £4 anywaycheck out this guy,,,,http://www.ajsutton.co.uk/supplies all derbi spares Quote
