Compression problem :(
We have a Suzuki AY50AK5 Katana R, is has a water cooled system. We bought with the compression problem, thinking we could sort it, we cannot find a manual, PDF or anything constructive to help. It is a 2007 and I think the A after the 50 denotes an Aprilia engine?
Hope you can help, many thanks :?
Hi
You should introduce yourself first:D Anyway i think this may help http://"http://moppeskroten.se/pdf/Aprilia/Aprilia%20sr50%20workbook.pdf If this is compression problem just replace piston and rings. Piston and rings can be buy from Ebay for 10 pound.
