Cbr 125 breaks
Hi I am currently bleeding my front break as there is some air in the system, I believe that may be a reason why my main break piston was stuck on. Any help on bleeding the breaks, and about my pistons not moving would be great.
Might be worth checking "Pitstop" probably a topic in there of someone with a similar problem.
Probably have to renew the seals if they are stuck. Easier than cleaning them out then finding it leaks. If you had trouble with google it's spelt brake :)
