Dan Posted March 17, 2014 Posted March 17, 2014 Hi All - This is hopefully a quickie.So the specs for my little Suzuki states the top speed is 63mph but the other day down a long incline i was pushing 75mph according to the speedo. The bike started to pull back or jolt It was like i was taking my hand all the way off the throttle except i wasn't.I'm wondering what caused this, was it simply my little 125cc engine gasping for air? I'm no mechanic but im guessing i should avoid doing it again. Quote
Marmalade43 Posted March 17, 2014 Posted March 17, 2014 It's probably got a rev limiter on it which stops you destroying the engine trying to get 100mph out of it.Also. the displayed 75 mph is likely a real world 60/65mph, speedos are accepted to read higher than actual speed.Strap a sat nav to it and try again, see the difference.My GSXR shows 175 on the speedo when you are doing 150 on the sat nav Quote
cockercas Posted March 17, 2014 Posted March 17, 2014 I rode my bike at 70mph + then a few days later got the juddering that you describe. It was the cdi unit breaking down. No idea if the speed was a contrabuting factor. Quote
al_stu Posted March 17, 2014 Posted March 17, 2014 My GSXR shows 175 on the speedo when you are doing 150 on the sat nav Taking the sat nav on a track? Quote
Marmalade43 Posted March 17, 2014 Posted March 17, 2014 My GSXR shows 175 on the speedo when you are doing 150 on the sat nav Taking the sat nav on a track? Of course, I wouldn't want to go the wrong way. Quote
littlecat Posted March 17, 2014 Posted March 17, 2014 sounds like rev limiter to me..... if its not meant to do more than 60 ish, don't do it Quote
hadster Posted March 17, 2014 Posted March 17, 2014 It's probably got a rev limiter on it which stops you destroying the engine trying to get 100mph out of it.Also. the displayed 75 mph is likely a real world 60/65mph, speedos are accepted to read higher than actual speed.Strap a sat nav to it and try again, see the difference.My GSXR shows 175 on the speedo when you are doing 150 on the sat nav In desperate need of a speedo healer lol Quote
Marmalade43 Posted March 18, 2014 Posted March 18, 2014 It's no worse than anything else. At 70 it says 76 on the clocks. Quote
