Right guys I've heard and read so many things about air/fuel n timings on the flywheel n stator but dose a speedfight 100 scooter have timing I see no adjustments on stator on the flywheel let me no.
N also how do I change the timings if I can ...
timing is all preset on rotor plate as the bike has electronic ign system and only way to alter/modify that is with race type set upyou dont want to g o messing about with timing anyway you will gain nothing but could create lots of problems in the future if you dont know what you are doing,as altering the timing will just make the spark happen earlier or later depending on what you do to it
