Guest Posted January 18, 2008 Posted January 18, 2008 hey everyone, looking to derestrict a yamaha dt 50 1989 http://img259.imageshack.us/img259/9577/image025qs8.th.jpg id rather not spend any money if possible but if theres no other options how much would it be? cheers Quote
Guest Posted January 18, 2008 Posted January 18, 2008 You should be able to do it yourself.Look between the carb and the inlet manifold. There will be a gasket with a smaller hole than the diameter of the inlet.....remove it.Voila!! Quote
Guest Posted January 18, 2008 Posted January 18, 2008 You should be able to do it yourself.Look between the carb and the inlet manifold. There will be a gasket with a smaller hole than the diameter of the inlet.....remove it.Voila!! Thanks very much!what kind of difference would it make? Quote
Guest Posted January 18, 2008 Posted January 18, 2008 You will definitely notice it but be careful!! Quote
Guest Posted January 18, 2008 Posted January 18, 2008 You will definitely notice it but be careful!! thanks very much! ill give it a try! any othe tips would be most appreciated Quote
Guest Posted January 18, 2008 Posted January 18, 2008 but be careful!! On a 50!! lol those 50cc's! bloody deathtraps Quote
