Need some help with my CBF125, back brake is barely slowing me down when I use it and is grinding/squeaking when I use it. Its a drum brake on the back, will I have to take the wheel off to check what the problem is?
yes you will need to drop wheel off the bike chances are there is a lot of brake dust build up in the drum causing you the problem,if you have never done it before take it slow and if needs be take pics of how the bolt look before you remove them and dont forget you will need to tension your chain again once you refit the wheel
