Changing motorbike parts
Hi, my Motoroma SK125 has suffered a drop and I've damaged the area around the speedo and ignition. I've searched the internet for hours and I can't find what I need for the bike, and the garages in my area say they don't work on Chinese motorbikes. So I was wondering if I'd be able to put a speedo from another bike on mine, or is this not possible?
I've put images below so you can get a better idea of what I mean
http://i60.tinypic.com/wbz8r5.jpg
http://i59.tinypic.com/5xpcgo.jpg
http://i58.tinypic.com/s2r234.jpg
http://i62.tinypic.com/15wc8c2.jpg
A quick google search of your bike to see what it looks like and the first link was to tesco with "currently no sellers".. my guess they've stopped being imported and parts dropped, I'd change out to another chinese brand eg; lexmoto whenever possible, will make life and part searching a lot easier, anyway..
CMPO (Chinese motorcycle parts online) stock a range of parts, non for your brand of bike unfortunately but may be worth a look;
http://www.chinesemotorcyclepartsonline.co.uk/
I'm not sure if you have the models number?
Lexmoto have a SK125-8 and SK125-22.. the SK125-8 (lexmoto ZSB) is currently being imported and parts haven't been made available yet, might be worth keeping an eye on when it does.. looks like the cloest model like for like to take a chance on;
http://www.lexmoto.co.uk/SK125-8.php
- Lexmoto Arrow
- Lexmoto Street
- Lexmoto ZSF
^ All basically look the same as the pictures you provide.. just a different speedometer design.
I own the Arrow, and have the following;
http://www.lexmoto.co.uk/HT125-4F_parts ... 125-4F.php
If all that fails.. then use the link below to find the closest lexmoto dealership to you, explain the brand of bike you have.. and inquire if the speedometers are able to be swapped out, to me it should be as easy as wiring it correctly.. they should be able to advise either way.
http://www.lexmoto.co.uk/dealers.php
Damage from sitting position ain't to bad.. you could live with that. The rear I'd look to bodge/custom something for that to cover. Maybe a nice square of plastic or mod a flyscreen to fit. Then you'd not even see it.
Must be really frustrating buddy but persevere!
Tonnes of flyscreen out there that fit the larger front light unit you have. You could bolt a universal one on then just seal up the instruments.
