Bought this bike at the weekend seller told me about dash fault.dash lights stay on,only light which works properly is neutral light and temp light.
Oil light flickers whilst revving.
All indicators lights work as usual.
Help would be greatly appreciated
I also have access to a multimeter
Apprantly happened when new motobatt was installed and mileage reset..
Motobatt is 12v8ah
i would worry about oil light flickering and get that one sorted first it will either be a bad connection at the switch itself not sure where it will be located on your bike but often underneath engine or behind crankcase under carb so either switch is shot loose connection or you have problem with oil pressure in the engine so dont go revving it to much untill you know for sure what the problem is
