I-AM-THOR Posted April 13, 2015 Posted April 13, 2015 Does anyone have any suggestions for a brick wall.Ground is Tarmac so a no go. Quote
Chrissb6 Posted April 13, 2015 Posted April 13, 2015 It's really depending on the type of wall your hoping to fix to. Is the garage single brick or double skinned block work or other ?? This one might fit the billhttp://www.sportsbikeshop.co.uk/motorcy ... prod/74307The question was asked can you fit it to a wall, they say you can depending of the type of wall and the material used. For me anything that will deter is better than nothing.Best of luck with your search Quote
dave_d Posted April 14, 2015 Posted April 14, 2015 I have a very similar one... seems pretty secure in brick with the correct security fittings. I have had a bar under mine to check! Quote
Marky Posted April 14, 2015 Posted April 14, 2015 There's also a couple sold by Pragmasis, which come with fixing kits for brick walls. Bit more expensive though. Quote
I-AM-THOR Posted April 14, 2015 Author Posted April 14, 2015 There's also a couple sold by Pragmasis, which come with fixing kits for brick walls. Bit more expensive though. The torc Doesnt charge any extra price. I've also asked about xena ones too, they only require one bolt and look nice and secure. I've also taken the comments first into consideration and emailed the company he suggested. Hopefully they come back with some options. Quote
