rice-pudding Posted June 12, 2015 Posted June 12, 2015 Just noticed that I have 1 snapped header bolt, looks quite flush with the head, dont know when or how long it's been like that. Is it still good to run or should I fix it ASAP? Everything still looks in place and there's no leaks coming from it. Quote
eastanglianbiker Posted June 12, 2015 Posted June 12, 2015 if its not leaking and you dont need to work on it then leave it alone untill such times as you do need to remove exhaust if you disturb it now it will start blowing so let it be untill you need to drill it out Quote
rice-pudding Posted June 13, 2015 Author Posted June 13, 2015 Thanks man. Yeah no leaks so I'll chance it just now, it's all coming in the future anyway so I'll repair it then Quote
