cockercas Posted June 20, 2015 Posted June 20, 2015 Im after a compressor, i only need it for blowing tyres up/touching up the bikes paint/small jobs.Is this any good?http://pages.ebay.com/link/?nav=item.vi ... 40&alt=web Could i go smaller? Should i go bigger? Quote
eastanglianbiker Posted June 20, 2015 Posted June 20, 2015 the more air you have stored the better as you need fairly big flow for spraying paint so also need good pump to keep pressure up that would be fine for little jobs but heavy useage would soon have it struggling i think Quote
Dav3y Posted June 20, 2015 Posted June 20, 2015 Unless you're intending to use air ratchets which require high cfm, that should be fine for light duty spraying/blowing up tyres.Seems a bit expensive though. I'm sure the going rate for them with the accessories is around £100.Check out machine mart if there is one local to you. Quote
cockercas Posted June 20, 2015 Author Posted June 20, 2015 I was thinking of buying one without the tools and then buying them as i need them.Tyre inflator and blow gun would be ok but i imagine id be better off with a better quality spray gun. Quote
