Treated her to a nice custom exhaust should be here this week with a 170 kit aswell http://images.tapatalk-cdn.com/15/10/27/582c57abaa6a9aa64a40ad9befea04e0.jpg
  • 2 weeks later...
More shiny bits have turned up http://images.tapatalk-cdn.com/15/11/05/72cf699bba9ffdc3bc75f09c29705e67.jpg
http://images.tapatalk-cdn.com/15/11/05/f99245966ec35a6d0e20231f52b2c4db.jpg
[emoji12]
  • 1 year later...
Well here it is my dtr project thread will start off with how it looked when I picked it up
http://images.tapatalk-cdn.com/15/08/03/b7c5e40372ad9f5619de3f883133650c.jpg
Your plain run of the mill 2001 dt125r non runner so out with the engine to start the rebuild and while I was at it came across a job lot of parts which included some dtx forks and wheels
http://images.tapatalk-cdn.com/15/08/03/7da1d19e822ece1fe9002b91de37a0c5.jpg
Then when the engine went back in I decided to spruce it up a bit with a lick of paint some new panels, headlight, dep exhaust, digital dash ect ect and this is how it stayed for a while
http://images.tapatalk-cdn.com/15/08/03/c0be9f0d836511468f7efde519f2099e.jpg
Then came mot time and I knew the fork seals were leaking so off came the forks so I could fit some new seals http://images.tapatalk-cdn.com/15/08/03/c187d55a3294b6cf931250abc486f789.jpg
While they were off I thought I may as well tidy her up a bit
http://images.tapatalk-cdn.com/15/08/03/de10353e8be91c1f9115f2f842c3d16f.jpg
Oops went a bit to far, so out came the tools and stripped and sprayed the frame and things started to go back together http://images.tapatalk-cdn.com/15/08/03/aff7cde0e3f1970fddf6360c9906b282.jpg
Then ended up with most of it all back together when I decided I might change a few bit http://images.tapatalk-cdn.com/15/08/03/15b4b74db461561f54cf38b6985a51c6.jpg
So after scouring ebay I stumbled across a few yz 125 parts and thought it would make a nice suspension up grade http://images.tapatalk-cdn.com/15/08/03/31928491b626106fb07c35aa7b9729af.jpg
So set about stripping the bike again to try and fit the forks and yokes so with a little fettling I managed to get them on
http://images.tapatalk-cdn.com/15/08/03/18365be8f792f09ca20f3856bd367a94.jpg
So then came to getting the dtx sm wheels to fit couple of custom spacers, inserts and spindle and the front was almost done http://images.tapatalk-cdn.com/15/08/03/08f4bbfb07b5e524327b4ae8e9137923.jpg
So thought I would move onto the back to see what I could do there so a lot more scouring through eBay and I came across a nice yz 250 alloy swing arm and thought how hard can it be http://images.tapatalk-cdn.com/15/08/03/0fdd2e044da012cda42b0adcec31328b.jpg
So while waiting on more custom bits to fit the rear swingarm I decided to test fit the dtx rear wheel which to my disappointment was not going to fit in the yz swingarm, so off I went to ebay again to try and find a solution a lot of time and money later I found onehttp://images.tapatalk-cdn.com/15/08/03/b52046cbf613ad568fe176dddd24129d.jpg
They came in the form of some yz/wr supermoto wheels, then came the fun of sourcing more parts like discs, sprockets, chain ect http://images.tapatalk-cdn.com/15/08/03/82f311e7eeb6f03321ca5118f6dc8453.jpg
And this is basically as far as I have got at the moment as waiting on more parts http://images.tapatalk-cdn.com/15/08/03/3a337baff3260f0a9d2af317e818370a.jpg
http://images.tapatalk-cdn.com/15/08/03/0c0c10aaff6dbe47816fc22c0f9dcea0.jpg
http://images.tapatalk-cdn.com/15/08/03/38cf53368d9f0ed2326c8eb88d25208c.jpg
If you have managed to read this far then thank you any comments good or bad are welcome cheers rick
Don't suppose you still have those spacers and insert for dtx wheels bud. I would love to buy em
the original poster of this hasnt been on here since november 2015 so might be worth sending him a private message as he will get email notification then and if he is still about he might reply
  • 5 months later...
