Any tips on adjusting a chinese 50cc carb? What to use or some kind of tutorial.
Rpms get stuck, problems with starting the bike, not enough pull from it (amount of air given).
what do you mean by rpms get stuck is it revving all the time and not going back to tick over properly if so it could be caused by a number of things from dodgy and damaged throttle cable or several other things
Rpms don't go back, maybe sometimes after a while, but usually stay high, throttle cable is new has been changed few days ago.
I'm 99% sure rantmachine will agree with my solution.
BUUUUUUUUUUUUUUURN IIIIIIIIIIIIIIIIIIIIIIIT
damn all these helpfull replies ............................when you replaced he throttle cable did you check everything was moving freely on the carb does the cable go into the top of the carb and pull the side up or does it go into a lever on the side of the carb?
I'd double check the throttle cable as EAB suggested. When you use the throttle does it snap back straight away when you release it?
Yes it snaps back and everything is good with the cable, bike only works perfectly fine at night time when I leave the gym.. Than next day, same thing, lesson learnt on chinese.
