can't see any hole on the tyre but it is losing air, if a shop fix it for me will it be a permanent fix? TA !!!
depends on where it is losing air from it could be as simple as the valve leaking or maybe not sealing correctly on the bead get some soapy water round the valve and beas to see if you can find it
