The back wheel arch (behind the bumper) has rotted abit.
Do i have to replace it with metal? Its the thin tinny stuff thats rotted but the suspension os mounted not far from it.
yes that has to be metal welded in place there is a proper repair section you can buy for that area i think you will find and its not to expensive and dont forget for the mot as its a repair panel it will need seam welding i doubt if you will be allowed to spot weld it
Yer ive seen a full pannel but it comes right up to the rail for the sliding door.
Might have to buy a welder and the pannel and cut the bottom part off and weld it behind the bumper trim
Thanks
It must be at least 30cm from the suspension mount, seatbelt mount or body mount. It wont fail if its outside prescribed area. It looks like the rust has set in and no doubt not the only area, on the earlier transits you end up chasing your tail so i would asses other areas before you decide to buy a repair panel.
