Hello, I am looking to buy a new engine for a 61 plate cbr 125 with current JC39E model, wondering if I can fit in a 2016 engine in it, which is most likely a JC50. Will it fit straight in with all the exhaust ports, electrics etc or will I have to change some bits?
Hi ,if your bike is the JC39e Engine with PGM-Fi ,then the 2016 engine should fit into that frame, Check with Fowlers Honda Parts Fische and you can see the 2011 frame runs up to 2016
