idle
Guest bmo831
My bikes sitting at 3000 rpm after it's warmed up, its only a 125 what can I do to reduce this cheers.
What type of bike is it to a start with? Carburettor or FI?
There's normally a a little knob as described by spanner but on some bikes it's just a screw on the carb. Screw in increases idle, screw out reduces typically. All changes should be made after going for a ride when the engine as at normal operating temp.
