http://moto.zombdrive.com/images1600_/aprilia-rx-50-racing-1.jpghttp://www.motorstown.com/newsImages/aprilia-sx-1.jpg
386_1361111231.jpghttp://www.aprilia.com/assets/aprilia-sites/master/models/moto/offroad/SX-50/main-image/2016/sx-my16-red/original/sx-my16-red.jpg
Pros
Italian styling
Reliable engine
Frugal mpg
Cons
Genuine spare parts availability, and shipping times from Italy
Exorbitant genuine spare parts profit margin
Flimsy fairing panel mounting lugs
SX 50 chain guard rubs off tyre wall
Wafer-thin, hard seat
Weak side stand springs
No side stand retaining hangar
Side stand bracket location interferes with left heel
Side stand bracket interferes with frame rail stands and lifts
Short frame length, cramped ride position
Kick start lever / pillion footrest clearance issue
Pillion footrest mounts not removable
Front footrests not wide enough
Footrest mounts not removable, not replaceable
No frame protectors to prevent ankles rubbing paint off
Handlebar mounts not removable, not rubber-mounted either.
Not luggage-friendly
2006-2009 headlight straps fray easily
Tall indicator switch, difficult to reach with thumb
Slow action throttle tube
Plastic radiator grille
2006-2009 SX 50 front mudguard too short
AJP Brake / clutch lever plastic bushings wear out fast
1-piece clutch cover
1-piece front sprocket guard
No battery box lid
No ignition cover gasket
Unreliable ignition stator
Unreliable digital speedometer
Loom wiring for speedometer made from cheese
Banana-skin rear brake pedal tip needs knurling
Microscopic fuel tank filler hole
Non-transparent fuel tank
Lockable tank cap is better than a lockable tank cap cover
Unreliable auto vacuum fuel tap
Fuel tap location on wrong side of the tank
Sensitive Dell'Orto carburetor
Left-mounted exhaust blocks access to carburetor
Airbox filter access requires removing RH side fairings
Cylinder head thermostat seizes shut. Common failure. Needs removing
No vibration-damping counterbalance gear, unlike the RS 50 / RS4 50
Fragile engine mounting lugs
Short suspension travel compared to bigger bikes
Basic push-rod suspension, soft spring rates, harsh ride, twitchy handling
Offset fork yokes exacerbate twitchy handling
No rubber fork gaiters / seal protectors
Non-adjustable rear shock absorber preload
2006-2010 models featured microscopic rear hub bearings
2006-2012 models featured insufficient 180mm rear brake disc
2013> SX models feature mag wheels with tubeless tyres
Crushed another dream. So which one is best?
The RX 50's larger wheels offer better ride comfort over potholes, and slower, less twitchy steering. If you like off-road adventuring, you'll be stood on the footrests often. So less butt-hurt from the plank of wood seat.
Would I recommend owning one?
NO
Many expensive design flaws. Not everything is fixable with aftermarket parts, or MacGyver bodges. You'll spend months waiting for OEM parts from overseas countries. Very unwise choice when it's your only mode of transport.
