After an aftermarket exhaust for my ybr, it’s a 13 plate.
Failing that a leadpipe that will fit in order to put on silencer..
Cheers
Are you wanting an exhaust for a YBR125 CUSTOM or are you after a "custom"exhaust for the bog standard YBR125?
If its the latter youll struggle to find anything used, as did i. I went with a Lextek downpipe and a slip on silencerth from ebay.
https://www.lextekproducts.com/DWNPP038
Its out of stock at the moment but check on it every day, it usually comes back in stock once a week. They arent a perfect fit, they do need some spacers under the nuts at the cylinder head but thats the only issue i had with fitting. if your bike is fitted with the emissions bollocks, youll need to block off the recirculation pipe that goes onto the pipe.
This is the only pic I actually have of it on my YBR.
25299538_1491368140917400_7180640180337856511_n.thumb.jpg.e6937160211b8fe03088e713cffac019.jpg
It might fit the YBR custom but Im not too sure on that.
