Admin Posted December 10, 2020 Posted December 10, 2020 2020 KTM 250 XC TPI (KTM/)The 250 XC TPI is another two-stroke dirt bike in the KTM lineup, now equipped with transfer port injection, which improves fuel efficiency, reduces exhaust emissions, and removes the need for rejetting a carburetor and premixing fuel.The TPI system on the 250 XC TPI is the same as what is used on the 300 XC-W TPI and 250 XC-W TPI enduro bikes, Dirt Rider covered. The 250 XC TPI off-road racer works its way around the track with a 250cc engine that is equipped with a new ambient air pressure sensor that aids in providing a smooth, crisp-running operation at any elevation.2020 KTM 250 XC TPI Reviews, Comparisons, And CompetitionThe KTM 300 XC TPI, Husqvarna TX 300i, and GasGas EX 300 are three other TPI-equipped two-stroke options to consider if you don’t mind an extra 50cc of displacement. If you’re set on a 250cc engine for your two-stroke cross-country machine, the Yamaha YZ250X is another model on the market.2020 KTM 250 XC TPI (KTM/)KTM 250 XC TPI Updates For 2020Plentiful updates are seen on the 250 XC TPI. For starters, there’s the addition of transfer port injection. The model also sees a new ambient air pressure sensor, exhaust system, and revised WP Xact suspension. The model is topped off with new graphics.2020 KTM 250 XC TPI (KTM/)2020 KTM 250 XC TPI Claimed Specifications Price: $9,799 Engine: Liquid-cooled single-cylinder two-stroke Displacement: 249cc Bore x Stroke: 66.4 x 72.0mm Horsepower: N/A Torque: N/A Transmission: 6-speed Final Drive: Chain Seat Height: 37.4 in. Rake: 26.1° Trail: N/A Front Suspension: 48mm inverted fork, fully adjustable; 12.2-in. travel Rear Suspension: Fully adjustable; 11.8-in. travel Front Tire: 90/90-21 Rear Tire: 110/100-18 Wheelbase: 58.5 in. Fuel Capacity: 2.3 gal. Dry Weight: 223 lb. View the full article Quote
