2020 MV Agusta F3 675
2020 MV Agusta F3 675 (MV Agusta/)
The MV Agusta F3 675 is a middleweight sportbike that has the formula for speed. It maximizes its 675cc triple’s power high on the tachometer which is exemplified in its claimed peak figures: 128 hp at a high 14,500 rpm and 52.0 pound-feet at 10,900 rpm. It is equipped with advanced electronics like ride-by-wire, up and down quickshifter, eight-level traction control, and rear-wheel-lift-mitigated ABS. It is also the first superbike to feature a counter-rotating crankshaft. Rev this machine to the moon and tuck in tight behind the fairing because it is race-ready if you are.
2020 MV Agusta F3 675 Reviews, Comparisons, And Competition
There are many middleweight sportbikes on the market. There’s the limited-edition Triumph Daytona 765, not to mention the competition seen in the Yamaha YZF-R6, Honda CBR600RR, Kawasaki ZX-6R, and Suzuki GSX-R600.
MV Agusta F3 675 Updates For 2020
No major updates were highlighted for 2020. The F3 is available in Ago Red/Ago Silver.
MV Agusta F3 675 Claimed Specifications
Price: 15,490 euros (est. $18,800)
Engine: Liquid-cooled DOHC three-cylinder
Displacement: 675cc
Bore x Stroke: 79.0 x 45.9mm
Horsepower: 128.0 hp @ 14,500 rpm
Torque: 52.0 lb.-ft. @ 10,900 rpm
Transmission: 6-speed
Final Drive: Chain
Seat Height: 32.7 in.
Rake: N/A
Trail: 3.9 in.
Front Suspension: 43mm inverted fork, fully adjustable; 4.9-in. travel
Rear Suspension: Fully adjustable; 4.8-in. travel
Front Tire: 120/70ZR-17
Rear Tire: 180/55ZR-17
Wheelbase: 54.3 in.
Fuel Capacity: 4.4 gal.
Dry Weight: 381 lb.
