A meteor is headed straight for the US in the form of a small-displacement cruiser. In celebration of 120 years in motorcycling, Royal Enfield has revealed its new 2021 Meteor 350. This bike captures the pure essence of cruising with timeless charm, all while providing universally approachable power, laid-back ergonomics, and admirable handling.
There’s a new beginner-oriented cruiser in town. The Royal Enfield Meteor 350.
There’s a new beginner-oriented cruiser in town. The Royal Enfield Meteor 350. (Jeff Allen/)
The Meteor’s air-/oil-cooled single sits in a twin downtube spine frame under a classically bulbous tank. The negative space between these components is alluring, even artistic. The electronically fuel-injected 349cc engine has a gentle, endearing thrum. Power delivery is gradual and steady, persuading the rider to relax and enjoy its leisurely pace in classic cruising fashion. On our in-house dyno this little single puts 17.4 peak hp and 18.2 pound-feet of torque to the rear wheel, but this power does not cause the bike to stammer or stutter on the roadway, whether traveling at a noted max speed of 70–75 mph on the freeway (stick to the slow lane) or navigating urban streets. A balance shaft does a great job in eliminating vibration in all conditions.
The Euro 5-compliant single-cylinder produces 17.4 hp and 18.2 pound-feet of torque on the <em>CW</em> dyno.
The Euro 5-compliant single-cylinder produces 17.4 hp and 18.2 pound-feet of torque on the <em>CW</em> dyno. (Jeff Allen/)
Engaging the five-speed gearbox is illuminating; the meaty clutch lever has an easy pull, but its engagement point is not exactly pinpoint-precise. And the location of the shift lever in relation to the chunky footpeg means my size 10 foot takes some wedging in there. Luckily there’s a heel shifter that’s a great alternative for getting through the gears.
A 29.7-inch seat height is easy for just about any size rider. Who can say no to an all-day comfortable seat?
A 29.7-inch seat height is easy for just about any size rider. Who can say no to an all-day comfortable seat? (Jeff Allen/)
A relaxed reach to the handlebars and casual foot-forward peg position make the ride superbly comfortable for all-day riding, especially with the Meteor’s wide, cushy, supportive seat. A good thing, too, considering this model has touring-focused trim.
Cruising with confidence-inspiring handling.
Cruising with confidence-inspiring handling. (Jeff Allen/)
On long highway straights and sinuous side roads, suspension and handling proved its worth with a comfortable and confidence-inspiring ride. The rigid chassis and 41mm fork provides good straight-line stability, and the bike maintains its intended line in turns even when uneven manhole covers and choppy road surfaces do their best to upset the bike. Wavy pavement makes the twin tube emulsion shocks wallow in troughs, but that’s a small price to pay for soft settings that usually soak up road imperfections well.
ABS is a standard-issue rider aid.
ABS is a standard-issue rider aid. (Jeff Allen/)
Braking with the front two-piston caliper/300mm disc combo does introduce some dive, and feel at the lever is mushy, but the bike’s measured 418-pound weight is carried low, and with the help of the rear single-piston caliper and 270mm disc, stopping performance is adequate.
Typically riders would have to go to the aftermarket for navigation products for their motorcycles. With the Meteor 350, the Tripper Navigation system comes standard and displays on the gauge on the right.
Typically riders would have to go to the aftermarket for navigation products for their motorcycles. With the Meteor 350, the Tripper Navigation system comes standard and displays on the gauge on the right. ( Jeff Allen/)
A simple gauge displays bare essentials on the analog speedometer and small LCD dash within, though the latter is difficult to see in direct sunlight. But, wait, there’s a smaller second gauge too. Royal Enfield dubs this little setup the Tripper navigation system, the first such in the RE family. Tripper is powered by Google Maps and the Royal Enfield app, connecting to a rider’s smartphone via Bluetooth to meet navigational needs. It’s a great, if standard, 21st century feature that’s actually not too common on beginner bikes. And if your phone’s in need of a charge, there’s also a USB charging port, another convenient bit of tech provided on this cruiser.
Under closer inspection, a touch of unrefined fit and finish can be seen. The base trim is handsome enough, with blacked-out details and pinstriping on the rims lending the Meteor a custom-bike aura, but sloppily wrapped wires mar an otherwise handsome vehicle.
An unexpected component on a cruiser…a centerstand.
An unexpected component on a cruiser…a centerstand. (Jeff Allen/)
Nicely shaped, inexpensive motorcycles shouldn’t be picked over too closely, lest you tarnish their charm. The Meteor 350 nails the classic cruiser vibe with its design, looks, and relaxed ergonomics, offering an easygoing ride with predictable power and handling. It’s a welcome air-cooled entry in the small-displacement cruiser market. Especially considering its starting price of $4,399, Royal Enfield most certainly has a contender against its liquid-cooled competition.
Mellow in Fireball Yellow. A ride down the boulevard is not a race, the Meteor invites the rider to relax and enjoy the ride.
Mellow in Fireball Yellow. A ride down the boulevard is not a race, the Meteor invites the rider to relax and enjoy the ride. (Jeff Allen/)
2021 Royal Enfield Meteor 350 Specifications
MSRP: $4,399
Engine: 349cc, SOHC, air/oil-cooled single
Bore x Stroke: 72.0 x 85.8 mm
Cycle World Measured Horsepower: 17.4 hp @ 6,090 rpm
Cycle World Measured Torque: 18.2 lb.-ft. @ 2,860 rpm
Fuel System: Electronic fuel injection
Clutch: Wet, multiplate
Frame: Twin downtube spine
Front Suspension: 41mm telescopic fork; 5.1 in. travel
Rear Suspension: Twin tube emulsion shocks, preload adjustable
Front Brake: 2-piston floating caliper, 300mm disc w/ ABS
Rear Brake: 1-piston floating caliper, 270mm disc w/ ABS
Wheels, Front/Rear: Alloy
Tires, Front/Rear: 100/90-19 / 140/70-17
Wheelbase: 55.1 in.
Cycle World Measured Seat Height: 29.7 in.
Fuel Capacity: 4.0 gal.
Cycle World Measured Wet Weight: 418 lb.
Availability: Mid-May 2021
Contact: royalenfield.com
GEARBOX:
If the dinosaurs saw this meteor coming at them, they would stop and look.
If the dinosaurs saw this meteor coming at them, they would stop and look. ( Jeff Allen/)
Helmet: Arai Regent X
Jacket: Pando Moto Capo Cor 01
Pant: Pando Moto Kusari Kev 01
Gloves: See See Street Glove
Boots: TCX Boots Street Ace Lady Waterproof
