BMW’s C 400 GT has been reworked for 2022.
BMW’s C 400 GT has been reworked for 2022. (BMW Motorrad/)
BMW originally jumped into the scooter market in a big way about a decade back with advanced high-performance 600cc and 650cc twins in well-designed chassis. Then, in 2017, the company adjusted its sights and introduced the C 400. The C 400 was originally available in two variants: the C 400 X for the urban commuter market and the C 400 GT for open road touring. Now the time has come for the BMW C 400 to upgrade to the latest Euro 5 standards.
The C 400 GT (the C 400 X is offered in markets outside the US) is powered by a 349cc single-cylinder unit (bore 80mm, stroke 69.6mm) featuring liquid-cooling and a single overhead cam four-valve head. The valves have generous dimensions: 32.5mm for the inlet and 27.2mm exhaust. With an 11.5:1 compression ratio and a 40mm throttle body, BMW claims the engine generates 34 hp at 7,500 rpm with torque peaking at 25.8 pound-feet at 5,750 rpm.
The 2022 BMW C 400 GT has an MSRP of $8,495.
The 2022 BMW C 400 GT has an MSRP of $8,495. (BMW Motorrad/)
The engine has undergone extensive upgrading to comply with Euro 5 regulations, starting with an electrically actuated, electronically managed throttle control and a new engine management system. The cylinder head has been modified and the idle speed regulator in the airbox has been omitted; idle speed control is now done through throttle-valve bypass and a turbulence system for a more stable idle. A new wideband oxygen sensor has been introduced to improve the exhaust system in conjunction with a new matrix coating on the catalytic converter. The CVT transmission’s centrifugal clutch has also been improved.
The new edition of BMW’s C 400 GT also receives an optimized Automated Stability Control system that provides an automatic recalibration of its basic parameters whenever the scooter undergoes a modification, say a change of tires. Before, these parameters had to be adjusted manually. Finally, the C 400 GT has an upgraded ABS braking system with new calipers and recalibrated lever feel. The front brake uses twin 265mm rotors teamed with four-piston floating calipers; at the rear, a 276mm rotor and a floating single-piston caliper.
Navigation is controlled via a full-color TFT dash.
Navigation is controlled via a full-color TFT dash. (BMW Motorrad/)
The chassis is basically unchanged; the BMW C 400 GT’s a generous 61.6-inch wheelbase ensures comfortable seating for two and rolls on 120/70-15 front and 150/70-14 rear radials up to a top speed of 87 mph. A 35mm telefork, with 26.4 degrees of steering rake and 3.2 inches of trail, and an aluminum rear swingarm handle suspension duties.
The 2022 BMW C 400 GT gets an LED headlight unit.
The 2022 BMW C 400 GT gets an LED headlight unit. (BMW Motorrad/)
The electronic suite includes a new ECU, a new Automatic Stability System (we can only assume that will change to something more acronym-friendly), and a powerful connectivity system incorporating a large TFT display for navigation and riding instructions.
Pricing starts at $8,495. The C 400 GT will arrive in US BMW dealers in spring 2021.
2022 BMW C 400 GT Specifications
MSRP: $8,495
Engine: SOHC, liquid-cooled single; 4 valves/cyl.
Displacement: 349cc
Bore x Stroke: 80.0 x 69.6mm
Compression Ratio: 11.5:1
Transmission/Final Drive: CVT/two-stage reduction gear
Claimed Horsepower: 34 hp @ 7,500 rpm
Claimed Torque: 25.8 lb.-ft. @ 5,750 rpm
Fuel System: Electronic port fuel injection w/ 40mm throttle body
Clutch: Centrifugal dry clutch
Frame: Steel tube w/ aluminum die-cast unit
Front Suspension: 35mm telescopic fork; 4.3 in. travel
Rear Suspension: Aluminum swingarm, dual spring struts, preload adjustable; 4.4 in. travel
Front Brake: 4-piston floating calipers, dual 265mm discs w/ ABS
Rear Brake: 1-piston caliper, 276mm rotor w/ ABS
Wheels, Front/Rear: Cast aluminum; 15 x 3.50 in. / 14 x 4.25 in.
Tires, Front/Rear: 120/70R-15 / 150/70R-14
Rake/Trail: 26.4°/3.2 in.
Wheelbase: 61.6 in.
Seat Height: 30.5 in.
Fuel Capacity: 3.4 gal.
Claimed Wet Weight: 472 lb.
Availability: Spring 2021
Contact: bmwmotorcycles.com
