ScoutPhilly Posted June 25, 2021 Posted June 25, 2021 Hi all My YBR 125 Custom (65 plate) started messing around at low revs, after searching the internet the symptoms point to the pilot jet being blocked as my fuel level was low. After reading up on how to clean a carburetor when I go to remove it from the bike it looks totally different, there seems to be no float bowl, does it have some sort of fuel injection system? I can't even locate the valve to turn the fuel off from the tank. Any advise greatly appreciated Please see photos below Quote
ScoutPhilly Posted June 25, 2021 Author Posted June 25, 2021 Problem solved, well I have found out it is a fuel injection system so onto stage two, strip it out and hopefully get it cleaned. Quote
