2021 Ducati SuperSport 950 S (Ducati Red)
2021 Ducati SuperSport 950 S (Ducati Red) (Ducati/)
  • Updated electronics with Bosch six-axis IMU at the controls
  • New windshield and seat enhance comfort
  • A versatile and practical everyday machine with fantastic composure on the track
  • Lost a few horsepower due to the Euro 5 switch
  • It’s not as powerful, light, or racy as the Panigale V2, but rather is a practical daily ride (see note above), which isn’t necessarily a bad thing.
The Ducati Supersport 950 proves that sportbikes don’t have to sacrifice comfort. With updates to the seat, windshield, bodywork, and electronics, this Ducati is a realistic daily and trackday machine.
2021 Ducati SuperSport 950 S (Arctic White Silk)
2021 Ducati SuperSport 950 S (Arctic White Silk) (Ducati/)
Providing a nice blend of comfort and sportiness with its upright ergos, adjustable windshield, memory-foam-padded seat, and a 110 hp (claimed) Testastretta engine wrapped in aggressive, new bodywork, the latest Ducati SuperSport is designed to be an everyday racer.
Updates for 2021
The SuperSport gets a refresh for 2021. The revamped styling gives it a Panigale-like aggressiveness with a new front fairing and new side fairings. A new windshield offers two height adjustability and a new memory foam-padded seat are comfort-forward amenities.
The SuperSport’s 937cc engine receives minor internal updates to meet Euro 5 emission standards. The clutch is now hydraulically actuated as well. Finally, the SuperSport adopts a six-axis Bosch IMU that manages traction control, wheelie control, and ABS rider-aid functions, which can be accessed via a new 4.3-inch TFT dashboard.
The SuperSport 950 starts at $13,495, with the S version coming in at $15,795 for Ducati Red and $16,195 for Arctic White Silk. The S model comes upgraded with a 48mm Öhlins fork and Öhlins shock, while the base model utilizes a 43mm Marzocchi fork and Sachs shock.
The 2021 Ducati SuperSport 950/S is powered by the 937cc Testastretta 11º L-twin. On both short straights or tight sections, the L-twin performed well. In his First Ride Review, Bruno dePrato reported: “The engine is strong; 120 mph was easily reached even with the relatively short straight at my disposal. The flexibility and density of low-rpm torque made it easy to fully exploit the bike on corner exits. Sport mode settings are perfect for everyday use on dry surfaces. For a final check on the flexibility of the 937cc Testastretta 11 engine I took a full lap, including some rather tight sections, using only sixth gear. Even when the engine was down to nearly 2,000 rpm, torque was adequate to move the bike along comfortably, with no shuddering or coughing.”
With load shifted forward over the clip-on handlebars for sporty riding, but a relatively long wheelbase, the SuperSport S “feel stable rounding full-blast 100-mph corners, yet it remains agile in very tight maneuvers at walking speed. It’s like no other Ducati I can remember,” dePrato wrote.
Braking is done by Brembo components on both model versions with two 320mm discs and four-piston Monoblock calipers (front) and 245mm disc and two-piston caliper (rear).
Claimed fuel consumption for the SuperSports is 100 kilometers/5.6 liters (62 miles/1.5 gallons or 41.3 mpg).
Mr. dePrato commented on the ergos of the 950 S, writing: “The clip-ons are set at the right height for comfort, but also ensure a rational sport-riding posture with plenty of load bias to the front.” When a long trackday ends with no aches and pains, that is a testament to the friendly riding position. The new memory-foam seat also adds to the comfort factor.
The Ducati’s Bosch IMU works with the rest of the electronics suite which includes cornering ABS, traction control, and wheelie control. A clutchless bidirectional (up and down) quickshifter also comes standard as do three ride modes (Sport, Touring, and Urban). Navigating through these settings can be done via the 4.3-inch TFT display and switches on the left handlebar.
A two-year, unlimited-mileage warranty is included for either the base or S models.
Practical, comfortable, versatile, and pure-bred Ducati. The SuperSport 950 and SuperSport 950 S are two models that have Panigale looks with a focus on everyday comforts.
Claimed Specifications
  2021 Ducati SuperSport 2021 Ducati SuperSport S
MSRP: $13,495 $15,795
Engine: 937cc, DOHC, liquid-cooled, 90-degree V-twin; 4 valve/cyl. 937cc, DOHC, liquid-cooled, 90-degree V-twin; 4 valve/cyl.
Bore x Stroke: 94.0 x 67.5mm 94.0 x 67.5mm
Transmission/Final Drive: 6-speed/chain 6-speed/chain
Fuel Delivery: Electronic fuel injection w/ 53mm throttle bodies; ride-by-wire Electronic fuel injection w/ 53mm throttle bodies; ride-by-wire
Clutch: Wet, multiplate, self-servo, slipper; hydraulic actuation Wet, multiplate, self-servo, slipper; hydraulic actuation
Engine Management/Ignition: N/A N/A
Frame: Tubular steel trellis, engine as stressed member Tubular steel trellis, engine as stressed member
Front Suspension: 43mm Marzocchi fork, fully adjustable; 5.1 in. travel 48mm Öhlins fork, fully adjustable; 5.1 in. travel
Rear Suspension: Sachs monoshock; 5.7 in. travel Öhlins monoshock, fully adjustable; 5.7 in. travel
Front Brake: Brembo Monoblock M4-32 4-piston radial mount calipers, radial master cylinder, 320mm semi-floating discs w/ Bosch Cornering ABS Brembo Monoblock M4-32 4-piston radial mount calipers, radial master cylinder, 320mm semi-floating discs w/ Bosch Cornering ABS
Rear Brake: 2-piston caliper, 245mm disc w/ Bosch Cornering ABS 2-piston caliper, 245mm disc w/ Bosch Cornering ABS
Wheels, Front/Rear: Aluminum 3-spoke; 17 x 3.50 in. / 17 x 5.50 in. Aluminum 3-spoke; 17 x 3.50 in. / 17 x 5.50 in.
Tires, Front/Rear: Pirelli Diablo Rosso III; 120/70ZR-17 / 180/55ZR-17 Pirelli Diablo Rosso III; 120/70ZR-17 / 180/55ZR-17
Rake/Trail: 24.0°/3.6 in. 24.0°/3.6 in.
Wheelbase: 58.3 in. 58.3 in.
Ground Clearance: N/A N/A
Seat Height: 31.9 in. 31.9 in.
Fuel Capacity: 4.2 gal. 4.2 gal.
Wet Weight: 463 lb. 463 lb.
Contact: ducati.com ducati.com
