Admin Posted July 21, 2021 Posted July 21, 2021 2022 Yamaha YZF-R7 (Team Yamaha Blue). (Yamaha/) Ups A fresh take at the outdated and expensive middleweight supersport market Well-balanced and addictive power via the CP2 powerplant Confidence-boosting and quick-handling chassis Approachable for newer and experienced riders alike Great visibility of dash information An enticing $8,999 price tag Downs Vague communication at the brake lever Lack of positive shift feel during gear changes Verdict With the tractable engine seen in the Ténéré 700 and MT-07, the R7 is a well-balanced machine for a great time at the track. It has confidence-boosting characteristics that make it appropriate for riders ranging in skill level. 2022 Yamaha YZF-R7 (Performance Black). (Yamaha/) Overview The new Yamaha YZF-R7 is the bLU cRU’s answer to the sales slump in the middleweight sportbike category. It houses the same 689cc parallel twin seen in the Ténéré 700 and MT-07, but is a fully faired and sport-focused option that replaces the outgoing R6. The new R7 targets the less experienced sportbike rider with its relatively affordable $8,999 price tag and all-new character. Updates for 2022 This is a new model for the 2022 model year. Pricing and Variants The 2022 Yamaha YZF-R7 has a starting MSRP of $8,999. Competition The YZF-R7′s competition includes Aprilia’s RS 660, Ducati’s Panigale V2, Suzuki’s SV650, Kawasaki’s Ninja 650, and Honda’s CBR650R. Powertrain: Engine, Transmission, and Performance The fun-loving, tractable 689cc parallel-twin engine and six-speed transmission make its way into the R7. The YZF-R7-specific slipper/assist clutch is claimed to reduce clutch pull by 20 percent. The lack of positive shift feel during gear changes is one gripe our test rider had during testing. And while power figures are not currently recorded, the MT-07 was run on the dyno and produced 67 peak horsepower and 46 pound-feet of torque and the R7 is expected to make the same. In his first ride review, Road Test Editor Michael Gilbert commented on the engine saying, “The power delivery is broad, the speed is exciting without being intimidating, and without massive horsepower to fall back on, rider skill in carrying corner speed is necessary to making good time. Smooth is fast.” 2022 Yamaha YZF-R7 (Team Yamaha Blue) (Yamaha/) Handling Differentiating the R7 chassis from the MT-07 are slightly revised dimensions, specifically, the rake is now 23.7 degrees, trail is 3.5 inches, and triple clamp offset is now 35mm. Overall this shortens the wheelbase by 5mm. Aluminum braces at the swingarm pivot increase torsional rigidity as well. Gilbert reported that the chassis “boosts confidence in a way even track-prepped MT-07s couldn’t. At a claimed 414 pounds fully fueled, the YZF-R7 is 8 pounds heavier than the MT, but is more nimble and more than willing to tackle quick side-to-side transitions and midcorner corrections. It also does so without requiring serious upper body strength to capitalize on its sporty handling” Brakes The R7 features a newly designed Brembo master cylinder paired with Advics radial-mounted calipers and 298mm discs at the front. 245mm discs are located out back. Nonswitchable ABS comes standard. Braking performance is reported to be strong, but feel at the lever struggles to precisely communicate brake pressure, Gilbert wrote. 2022 Yamaha YZF-R7 (Performance Black). (Yamaha/) Fuel Economy and Real-World MPG Yamaha claims that this supersport racks in 58 mpg from the 3.4-gallon fuel tank. Ergonomics: Comfort and Utility According to Yamaha, the R7 is the slimmest in its sportbike lineup. Gilbert concurred on its narrowness in his report: “It’s tight between the legs and an appropriate fit for my racer-sized 5-foot-7-inch frame. The aggressive control position is also favorable; modeled after the outgoing YZF-R6, the lower stance is sporty and allows the R7 to be hustled underneath you, while the clip-on handlebars are positioned slightly higher to reduce fatigue, a positive for everyday street riding.” 2022 Yamaha YZF-R7 (Performance Black). (Yamaha/) Electronics LED lighting is found at both the front and the rear and a new LCD dash displays information such as gear position, fuel capacity, real time and average fuel economy, water temp, clock, speed-, tach-, and odometers all operated from handlebar switches. Warranty and Maintenance Coverage The R7 has a one-year limited factory warranty. Quality Quality is as you would expect from Yamaha. The R7 offers a balance of power and an approachability that makes it a fitting replacement for the outgoing R6. 2022 Yamaha YZF-R7 (Team Yamaha Blue). (Yamaha/) 2022 Yamaha YZF-R7 Claimed Specifications MSRP: $8,999 Engine: 689cc, DOHC, liquid-cooled parallel twin; 4 valves/cyl. Bore x Stroke: 80.0 x 68.6mm Transmission/Final Drive: 6-speed/chain Fuel Delivery: Fuel injection w/ 38mm throttle bodies Clutch: Wet, multiplate assist/slipper Engine Management/Ignition: N/A Frame: Tubular-steel double backbone Front Suspension: 41mm KYB inverted fork, fully adjustable; 5.1 in. travel Rear Suspension: KYB shock, spring preload and rebound adjustable; 5.1 in. travel Front Brake: 4-piston Advics calipers, dual 298mm discs w/ ABS Rear Brake: 1-piston Nissin caliper, 245mm disc w/ ABS Wheels, Front/Rear: 17 in. / 17 in. Tires, Front/Rear: Bridgestone Battlax Hypersport S22; 120/70-17 / 180/55-17 Rake/Trail: 23.7°/3.5 in. Wheelbase: 54.9 in. Ground Clearance: 5.3 in. Seat Height: 32.9 in. Fuel Capacity: 3.4 gal. Wet Weight: 414 lb. Contact: yamaha-motor.com View the full article Quote
