Hi,I hope somebody can help with a problem I have with my 2002 Bonneville. The problem is that when I close the throttle you can hear the linkage snap shut, but the revs only come back slowly. Any ideas would be appreciated. Cheers.
Sounds like you have an air leak of some description. This will lean the mixture out and cause the revs to hang.
  • 2 weeks later...
Either that or you have an air fuel mixture problem. Had a similar issue with my bandit when I was setting the carbs up, they were running too rich and causing the revs to hang.
