From Britain with Love. Meet the Triumph Speed Triple RR Bond Edition, celebrating 60 years of Bond films.
From Britain with Love. Meet the Triumph Speed Triple RR Bond Edition, celebrating 60 years of Bond films. (Triumph Motorcycles/)
As with new-age Daniel Craig Bond’s attire, the 178 hp Speed Triple RR keeps its color palette dark. The bike arrives with a  three-color paint scheme in Black, Granite Grey, and Storm Grey, with the official “60 Years of Bond” commemorative logo on the tank sides.
Each 60 Bond Edition Speed Triple RRs will arrive with a special number plate.
Each 60 Bond Edition Speed Triple RRs will arrive with a special number plate. (Triumph Motorcycles/)
Triumph says the bike’s cockpit is designed to mimic a gun barrel “reminiscent of probably the most iconic film opening sequence of all time.” Typical of other Triumph customs, the bike features hand-painted gold trim across the cockpit and rear tail. The Bond look is furthered with premium custom-made gold logos that match the Öhlins fork on the tank and side fairing.
The Öhlins’ Smart EC 2.0 semi-active electronic fork is a perfect complement to the custom paint.
The Öhlins’ Smart EC 2.0 semi-active electronic fork is a perfect complement to the custom paint. (Triumph Motorcycles/)
The Speed Triple 1200 RR Bond Editions are individually numbered from 1 to 60 on a handlebar clamp badge which also features official James Bond branding. Each RR will also arrive with a custom 007 indoor bike cover and a unique certificate of authenticity, hand-signed by Triumph CEO Nick Bloor.
Gold lining is used throughout the body of the Speed Triple RR Bond Edition.
Gold lining is used throughout the body of the Speed Triple RR Bond Edition. (Triumph Motorcycles/)
All else is pure Speed Triple RR, the naked sportbike Triumph launched for 2022 by adding some sportier additions to the Speed Triple RS, including clip-on handlebars, relocated footpegs, a new front fairing, and Öhlins’ Smart EC 2.0 semi-active electronic suspension. The RR, which is powered by the 1,160cc triple that delivers 178 hp and 92 lb.-ft. of torque, also arrives with Pirelli Diablo Supercorsa SP V3 tires, a full-color TFT instrument with My Triumph connectivity, cornering ABS, and switchable cornering traction control.
For more, read our 2022 Triumph Speed Triple RR First Ride Review.
The Speed Triple RR Bond Edition’s cockpit is designed to mimic a gun barrel “reminiscent of probably the most iconic film opening sequence of all time.”
The Speed Triple RR Bond Edition’s cockpit is designed to mimic a gun barrel “reminiscent of probably the most iconic film opening sequence of all time.” (Triumph Motorcycles/)
Bond exclusivity includes a $4,000 premium over the base RR. The 2023 Speed Triple RR Bond Edition’s price is $24,995, and requires special ordering.
The Bond Edition Street Triple silhouette delivers powerful spylike imagery. Or, as Bond would say, “There's a saying in England: Where there's smoke, there’s fire.”
The Bond Edition Street Triple silhouette delivers powerful spylike imagery. Or, as Bond would say, “There's a saying in England: Where there's smoke, there’s fire.” (Triumph Motorcycles/)
Speaking of Bond exclusivity, the Triumph Scrambler 1200 XE stunt bike used in the filming of No Time to Die was auctioned to an online bidder for $154,317. All proceeds went to Severn Hospice to celebrate 60 years of James Bond films. Triumph Motorcycles provided the Scrambler 1200 XE that Daniel Craig rode along with stunt riders Paul Edmondson and Martin Craven while filming No Time to Die.
The looks are there, and so is the punch. This Speed Triple RR Bond Edition delivers 178 hp, which is, as Bond would say, “Shocking. Positively shocking.”
The looks are there, and so is the punch. This Speed Triple RR Bond Edition delivers 178 hp, which is, as Bond would say, “Shocking. Positively shocking.” (Triumph Motorcycles/)
2023 Triumph Speed Triple 1200 RR Bond Edition Specifications
MSRP: $24,995
Engine: DOHC, liquid-cooled, inline 3-cylinder; 12 valves
Displacement: 1,160cc
Bore x Stroke: 90.0 x 60.8mm
Compression Ratio: 13.2:1
CW Measured Horsepower: 151.5 hp @ 10,500 rpm (2022 Speed Triple 1200 RR)
CW Measured Torque: 82.6 lb.-ft. @ 8,500 rpm (2022 Speed Triple 1200 RR)
Fuel System: Multipoint sequential electronic fuel injection w/ electronic throttle control
Clutch: Wet, multiplate, slipper/assist function
Frame: Aluminum twin spar; bolt-on aluminum rear subframe
Front Suspension: Öhlins 43mm fully adjustable USD fork; S-EC 2.0 OBTi system electronic compression and rebound damping; 4.7 in. travel
Rear Suspension: Öhlins monoshock RSU w/ linkage; S-EC 2.0 OBTi system electronic compression and rebound damping; 4.7 in. travel
Front Brake: Brembo Stylema Monoblock 4-piston calipers, dual 320mm floating discs w/ OC-ABS
Rear Brake: Brembo 2-piston caliper, 220mm disc w/ OC-ABS
Wheels, Front/Rear: Cast aluminum; 17 x 3.5 in. / 17 x 6.0 in.
Tires, Front/Rear: Pirelli Diablo Supercorsa SP V3; 120/70ZR-17 / 190/55ZR-17
Rake/Trail: 23.9º/4.1 in.
Wheelbase: 56.7 in.
Seat Height: 32.7 in.
Fuel Capacity: 4.1 gal.
Average MPG: 35.1 mpg
Claimed Wet Weight: 438 lb.
Availability: January 2022
