Supermoto-inspired bodywork and hardware separate the KLX300SM from the dual-sport models.
Supermoto-inspired bodywork and hardware separate the KLX300SM from the dual-sport models. (Kawasaki/)
The KLX300SM lightweight supermoto motorcycle takes the fun to the streets in full supermoto style. Developed alongside the KLX300 dual-sport, the KLX300SM shares a similar engine and chassis with its dual-sport counterpart. The models differ in terms of styling and purpose, as the KLX300SM receives a host of supermoto inspired components. These include 17″ front and rear wheels paired with street tires, supermoto tuned suspension, and unique styling. A quick-revving engine, paired with light, agile handling, brings out the bike’s playfulness.
The 2023 KLX300SM is available in two color options: Lime Green and Fragment Camo Gray.
The 2023 KLX300SM is available in two color options: Lime Green and Fragment Camo Gray. (Kawasaki/)
The 2023 KLX300SM is available in Lime Green for $5,899 and Fragment Camo Gray for $6,099.
A compact and purpose-built chassis is designed to offer lightweight, maneuverable handling.
A compact and purpose-built chassis is designed to offer lightweight, maneuverable handling. (Kawasaki/)
2023 Kawasaki KLX300SM Claimed Specifications
MSRP: Lime Green ($5,899) / $6,299 (Fragment Camo Gray)
Engine: 292cc, DOHC, liquid-cooled single; 4 valves
Bore x Stroke: 78.0 x 61.2mm
Fuel Delivery: DFI w/ 34mm throttle bodies
Engine Management/Ignition: Digital DC-CDI
Frame: Semi double-cradle
Front Suspension: 43mm inverted cartridge fork with adjustable compression; 9.1 in. travel
Rear Suspension: Uni-Trak with adjustable preload, compression, and rebound; 8.1 in. travel
Front Brake: 2-piston caliper, 300mm disc
Rear Brake: 1-piston floating caliper, 240mm disc
Wheels, Front/Rear: Spoked; 17-in. / 17 in.
Tires, Front/Rear: 110/70-17 / 130/70-17
Rake/Trail: 25.0°/2.8 in.
Wheelbase: 56.5 in.
Ground Clearance: 9.3 in.
Seat Height: 33.9 in.
Fuel Capacity: 2.0 gal.
Wet Weight: 304 lb.
Contact: kawasaki.com
