Hi to you all  . I do need some help. Lexmoto Enigma rustbucket playing up something rotten. Havnt got a clue . Starts from cold  but won't idle.  From cold, 5 to 10 min warm up,  you move off , get to about 30 and she starts to slow,  give more throttle,  engine gets louder but scoot continues to slow, let go of throttle and she quickly grinds to halt and stalls out. Murder to restart, lights dimming etc. Repeat two or three times then rides normally  occasionally stalling even when warmed up. New injector, coil, spark plug, battery,  kill switches,  throttle body. I'm done lol.
Have you tried turning the engine by hand and seeing if it feels like it’s spinning smoothly. Sounds like there is a lot of friction somewhere.
  • 2 weeks later...
On 06/11/2022 at 18:36, bud said:
Have you tried to see if the OBD shows any fault codes?
It's finding a garage with the chinesium connector.  Most garages won't touch it because it's chinesium.
It's probably just an OBD2 connection. You can get the readers quite cheaply now.
