Admin Posted February 15, 2023 Posted February 15, 2023 The <i>Cycle World</i> Ten Best–winning BMW K 1200 LT was available with an electrohydraulic centerstand as an option. (Cycle World Archives/) While a power-assisted centerstand might not sit at the very top of your “must-have” list when choosing a new motorcycle, there’s clearly a market for the technology. Several aftermarket brands sell variations on the idea and OEMs have dabbled in it as well. One of them is BMW, and a new patent shows the firm has ideas to improve the system on future models. BMW’s powered centerstand was an option starting on the 2004 K1200LT, using a combination of electrics and hydraulics to take the effort out of heaving the heavy tourer onto its stand, but the company is now working on a version of the idea that’s intended to be much more natural to use. Instead of a slow, push-button-operated system, the idea is to create a stand that works exactly like a conventional, manual one, but without the effort. The previous electrohydraulic centerstand from BMW’s 2004 K1200LT required the rider to press a button and then wait for the system to slowly jack the bike up onto the stand. (Cycle World Archives/) While many are sure to argue that putting a bike on its centerstand is a question of technique rather than brute strength, and there’s truth to that, we’re living in a world where everything is getting power assistance. Electronic suspension adjustment is becoming commonplace, throttles are controlled via servos rather than cables, and even power steering is being trialed on motocross bikes by Yamaha right now. With that in mind, the idea of using bodyweight and muscle power to hoist a bike onto its stand seems anachronistic. If there’s a cheap, compact, and user-friendly way to make a power stand, then why not? BMW’s new patent application describes the problem, saying, “In the case of motorcycles that are particularly bulky…jacking up the motorcycle in this way can require a particularly large amount of muscle power on the part of the user.” While acknowledging that leverage can be increased with a longer arm on the stand, the patent points out that this creates its own problems in terms of packaging. The new patent suggests that the system is more of an assist feature than a fully automated function. (BMW/) But if BMW has made power stands in the past, what’s new about the latest patent? The answer lies in speed and usability. Instead of pressing a bar-mounted button and waiting for an electric motor to drive a hydraulic pump, slowing cranking the stand into position while you try to hold the bike steady, the initial stage of lowering the new stand is completely conventional. There’s a peg extending from one side, and you push it down with your foot. Only when the stand touches the ground does the power element come into play. When the system senses that the stand touches the ground, it then applies helping assist. It can also be disabled completely. (BMW/) A sensor on the stand registers when it hits the ground and you start to put more pressure on the lever, adding power assistance to help jack the rear of the bike up and pull it onto the stand. The patent also suggests there are buttons to activate the system on the bars and the rear grab handle that can be used to control the power assist system once the bike is being lifted. The system also allows power assistance to be decoupled entirely, allowing the stand to be used manually and letting you quickly push the bike off the stand, rather than waiting for it to retract electrically. Although the existence of the patent doesn’t mean the system is on the verge of being incorporated into a production bike, it’s a design that makes sense in light of BMW’s ever-advancing rider-assistance technology. With a new generation of boxer-twin BMW is expected to debut this year when the R 1300 GS is launched, including a radically different chassis and engine design compared to the current models, there’s a possibility that the power stand shown in the patent will come at the same time. View the full article Quote
