scottz800 Posted May 21, 2023 Posted May 21, 2023 (edited) Hi all, So I've recently fitted some sequential LED indicators to my bike and they aren't working properly from what i can find on the forum is to either put resistors in or replace the relay. I don't want to go down the resistor route as I'm not sure of the wattage of the indicators and its a bit more work then just replacing the relay. So the relay, does it matter on the min/ max wattage of it ? as from what i can gather they draw minimal any way which is what causes them to fast flash/not work properly. Relays ive found so far range from 1-50 up to 1-200 watt. two pin relay on a Kawasaki Z800. Thanks. Edited May 21, 2023 by scottz800 Quote
