Triumph’s 2024 Scrambler 400 X will arrive in dealers early 2024.
Triumph’s 2024 Scrambler 400 X will arrive in dealers early 2024. (Triumph Motorcycles/)
The second model in Triumph’s new “TR Series” range of single-cylinder bikes might share a platform with the entry-level Speed 400 but it adds an on-point scrambler style that’s likely to make it the bigger seller of the pair.
Called the Scrambler 400 X, it shares the same all-new 398cc single-cylinder engine as well as borrowing the Speed 400′s 3.4-gallon tank and side panels, but it’s more than just a set of wheels and longer fork. Triumph has tweaked the frame design to suit the Scrambler, and changed the seat, bars, and pegs to give a distinct stance and riding position. The result is a bike that manages to carve a distinct niche as a retro-styled alternative to modern mini-adventure models like BMW’s G 310 GS and even KTM’s 390 Adventure.
Triumph sees most of the Scrambler 400 X’s time will be spent on the street (like most scramblers and ADV bikes), despite getting longer-travel suspension. Metzeler Karoo Street tires reveal the X’s true capability in the dirt.
Triumph sees most of the Scrambler 400 X’s time will be spent on the street (like most scramblers and ADV bikes), despite getting longer-travel suspension. Metzeler Karoo Street tires reveal the X’s true capability in the dirt. (Triumph Motorcycles/)
Let’s start with what’s shared across the new TR-series range. The engine is a DOHC four-valve single with finger followers to reduce valve train inertia and a reverse-rotating balancer shaft to reduce vibrations. Kicking out 39.5 hp at 8,000 rpm and 27.7 lb.-ft. of torque at 6,500 rpm, it’s in the same state of tune as the Speed 400. Power is driven though the same assist-and-slipper clutch and six-speed box, but with a revised final drive ratio to suit the larger diameter of the higher-profile rear tire. As on the Speed 400, there’s switchable traction control and a long, 10,000-mile service interval.
Not that it’s a serious off-roader, but there are nods to dirt-road use, including more travel from the suspension. There’s 5.9 inches of stroke front and rear—increases of 0.4 inch and 0.8 inch, respectively, compared to the Speed 400. Triumph also fit the 400 X with different wheels (a half-inch narrower at each end) and with a 19-inch front instead of the roadster’s 17-incher. Slightly chunky tread means the Metzeler Karoo Street tires will cope with loose surfaces, but they’re named “Street” for a reason.
A 398cc TR-series single puts out a claimed 39.5 hp at 8,000 rpm.
A 398cc TR-series single puts out a claimed 39.5 hp at 8,000 rpm. (Triumph Motorcycles/)
Elsewhere, the addition of hand guards, a grille over the headlight, a bash guard under the engine, and a radiator protector conspire to tick all the right scrambler boxes. There’s a different end can on the exhaust, but unlike the Scrambler 900 and Scrambler 1200 models, the Scrambler 400 X doesn’t get a high-level exhaust wrapping around the side of the engine. That’s because it has the same, hidden main muffler and catalytic converter under the engine as the Speed 400.
The frame, described as a hybrid spine/perimeter design like that of the Speed 400, is stretched by around an inch at the steering head. Along with the longer-travel suspension and bigger front wheel, it adds 1.6 inches to the wheelbase, taking it to 55.8 inches, but the rake is steeper than the Speed 400′s, cut from 24.6 degrees to 23.2 degrees. The bars are wider and taller and the footpegs are lower, farther forward, and more broadly spaced, as well as being made of steel instead of aluminum and gaining removable rubber inserts.
Inevitably, the taller suspension increases the seat height, but at 32.8 inches it’s still low enough to be suitable for most riders. Weight is also increased compared to the Speed 400, but only by 20 pounds for a total of 395 pounds with a full tank of fuel.
There’s more sharing when it comes to the brakes. The Scrambler 400 X’s ByBre four-piston radial front caliper is the same as the Speed 400′s, but it acts on a larger, 320mm disc instead of the roadster’s 300mm version. The rear brake is identical, with a 230mm rotor and single-piston caliper. In case you venture off-road, the Scrambler 400 X’s ABS can be switched off, unlike the system on the Speed 400.
ABS is switchable on the Scrambler 400 X—a must for any real dirt duty.
ABS is switchable on the Scrambler 400 X—a must for any real dirt duty. (Triumph Motorcycles/)
The entire TR-series project is a joint effort between Triumph and Indian brand Bajaj, a partnership that was announced back in August 2017. That’s an indication of the level of work that’s gone into the new models, which hold the promise of making the brand accessible to whole swaths of riders who wouldn’t previously have been shopping for a Triumph. That includes young and inexperienced riders in markets like Europe and the USA, while in Asia and India the new 400s will be positioned as mainstream offerings for experienced motorcyclists.
Although much is shared between the Speed 400 and Scrambler 400 X, it’s clear Triumph equipped and developed the two for two different missions.
Although much is shared between the Speed 400 and Scrambler 400 X, it’s clear Triumph equipped and developed the two for two different missions. (Triumph Motorcycles/)
Although Bajaj is also deeply involved with KTM, owning a stake in the Austrian company and manufacturing single-cylinder bikes on its behalf as well as the related Husqvarna Svartpilen and Vitpilen models, the Triumph project is independent of those machines.
Longer-travel suspension, a bigger front rotor, and Scrambler specific geometry give the Triumph Scrambler 400 X the ability to cope with loose surfaces.
Longer-travel suspension, a bigger front rotor, and Scrambler specific geometry give the Triumph Scrambler 400 X the ability to cope with loose surfaces. (Triumph Motorcycles/)
Like the Speed 400, the Scrambler 400 X is due to be in dealers at the start of 2024 in the US. Triumph’s existing factories in Thailand and Brazil will be tasked with making the bikes, which are also set to roll out of Bajaj’s plants in India. Indian buyers will be able to get the bikes much sooner, with sales starting in August this year, so we should soon have a sign of how well they compete with established rivals in that market. Prices for the US versions will be announced nearer their launch date but the rival BMW G 310 GS, at $5,695, sits in the market Triumph is targeting so the Scrambler is unlikely to be too far from that mark.
We have all kinds of ideas for the Scrambler 400 X already…
We have all kinds of ideas for the Scrambler 400 X already… (Triumph Motorcycles/)
2024 Triumph Speed 400 Specs
MSRP: TBA
Engine: DOHC, liquid-cooled single-cylinder; 4 valves
Displacement: 398cc
Bore x Stroke: 89.0 x 64.0mm
Compression Ratio: 12.0:1
Claimed Horsepower: 39.5 hp @ 8,000 rpm
Claimed Torque: 37.5 lb.-ft. @ 6,500 rpm
Fuel System: Bosch electronic fuel injection w/ electronic throttle control
Clutch: Wet, multiplate slipper/assist; cable actuated
Frame: Hybrid spine/perimeter, tubular steel; bolt-on rear subframe
Front Suspension: 43mm inverted Big Piston fork; 5.9 in travel
Rear Suspension: Gas monoshock w/ external reservoir;, spring preload adjustable; 5.9 in. travel
Front Brake: 4-piston radial caliper, 320mm fixed disc w/ ABS
Rear Brake: Floating caliper, 230mm fixed disc w/ ABS
Wheels, Front/Rear: Cast Aluminum; 2.5x19” / 3.5x17”
Tires, Front/Rear: Metzeler Karoo Street; 100/90R-19 / 140/80R-17
Rake/Trail: 23.2°/4.3 in.
Wheelbase: 55.8 in.
Seat Height: 32.8 in.
Fuel Capacity: 3.4 gal.
Claimed Wet Weight: 395 lb.
