2024 Aprilia Tuareg 660 Gets New Colors and Air Filter
New colors and air filter define the changes to the 2024 Aprilia Tuareg 600.
New colors and air filter define the changes to the 2024 Aprilia Tuareg 600. (Aprilia/)
Aprilia took the domain of adventure bikes by surprise when it unveiled the twin-cylinder Tuareg 660. The Tuareg takes advantage of the great versatility of the 660cc parallel-twin engine derived from the 1,100cc V-4 unit that led the RSV 1000 to an impressive dominance in Superbike competition.
The versatility of the 660 twin comes from its rather exclusive combination of compact size, low weight, and usable power and torque to play with in relation to the mission of the motorcycle model. The displacement comes from a combination of 81mm bore and 64mm stroke. The forged crankshaft features 270-degree set crank throws to obtain good balance with the assistance of a single countershaft. In the specific case of the Tuareg, the twin runs at 13.5:1 compression ratio and breathes through 48mm throttle bodies. Specific cam profiles and timing have been developed to obtain a claimed 80 peak horsepower at 9,250 rpm and 51.6 lb.-ft. peak torque at a very moderate 6,500 rpm. Almost 3,000 rpm separates peak torque from peak power translating into a highly responsive and flexible engine, which is a primary virtue in an adventure bike intended for strong off-road performance.
2024 Aprilia Tuareg 660 in Canyon Sand.
2024 Aprilia Tuareg 660 in Canyon Sand. (Aprilia/)
The twin sits in a steel tubing trellis frame via six connection points and the rear swingarm pivot axle is solidly attached by going through both the frame plates and a massive boss in the crankcase. Suspension is by Kayaba at both ends and delivers 9.4 inches (240mm) of wheel travel and is optimized for road and off-road riding. Granting solid capability at negotiating very rough terrain, 21-inch front and an 18-inch rear wheels have been selected and shod with Pirelli Scorpion Rally STR tires. To reduce the flywheel effect at the front end, Brembo 300mm rotors have been adopted and teamed to twin-piston calipers to ensure adequate braking power.
Aprilia Tuareg was designed by famous designer Miguel Galluzzi at Piaggio Advanced Design Center in Pasadena, and it looks very slim, elegant, and functional with everything rationally located not to interfere with the rider’s action. As per Aprilia tradition, the electronics suite is at the top for its number of functions and quality, assisting with both riding pleasure and safety. Aprilia Tuareg is compact and light for its class.
2024 Aprilia Tuareg 660 in Atreides Black.
2024 Aprilia Tuareg 660 in Atreides Black. (Aprilia/)
Dry weight is a claimed 412 pounds and the chassis spans a 60-inch wheelbase and a very accurate attention to the proper location of the engine accessories has brought the seat height down to 33.9 inches, which is very positive given the tall suspensions and related wheel travel.
The Tuareg already proved its capabilities in a number of competitions that might grant it the Italian Motorally title. In addition, a privately entered bike finished third in the Transanatolia Rally. Given the positive debut in competition, next year it will be entered in the more international events.
Given the positive response of the public, for 2024 Aprilia Tuareg only received styling and graphics updates, with new colors created to enhance its racing spirit. The chassis now is painted red and looks great in combination with the new Atreides Black and Canyon Sand colors. A racing-inspired Dakar Podium color is an homage to Aprilia’s third place finish in the 2010 Dakar Rally with the RXV 4.5 rally racer. On the technical side, the only addition is a new air filter specifically conceived to protect the engine from the dust and sand of the roughest off-road rides.
2024 Aprilia Tuareg 660 in Dakar Podium.
2024 Aprilia Tuareg 660 in Dakar Podium. (Aprilia/)
2024 Aprilia Tuareg 660 Specs
MSRP: $12,299/$12,699 (Dakar Podium)
Displacement: 659cc
Bore x Stroke: 81.0 x 63.9mm
Compression Ratio: 13.5:1
Claimed Horsepower: 80 hp @ 9,000 rpm
Claimed Torque: 51.6 lb.-ft. @ 6,500 rpm
Fuel System: Fuel injection w/ 48mm throttle bodies; ride-by-wire
Clutch: Wet, multiplate, slipper function
Frame: Steel
Front Suspension: Kayaba 43mm inverted fork, fully adjustable; 9.4 in. travel
Rear Suspension: Kayaba piggyback shock, fully adjustable; 9.4 in. travel
Front Brake: Brembo 4-piston calipers, dual 300mm discs w/ ABS
Rear Brake: Brembo 1-piston caliper, 260mm disc w/ ABS
Tires, Front/Rear: Tubeless; 90/90-21 in. / 150/70R-18 in.
Rake/Trail: 26.7°/4.5 in.
Wheelbase: 60.0 in.
Seat Height: 33.9 in.
Fuel Capacity: 4.8 gal.
Claimed Dry Weight: 412 lb.
Availability: October 2024
Contact: aprilia.com
