my pw50 was running OK till tte other day now it starts but wont rev out, iv changed the throttle cable and cleaned the carb n jets out but still no change any advise would be helpfull
Posted (edited)
The handlebar switch has a start position and run position.  If you start it and forget to put the switch to run, it will do as you describe.
So you forgot to move the switch or the switch has gone faulty.  If not, look to other issues like a blocked exhaust.
Edited by Tinkicker
