Quackerzakieee Posted February 7, 2024 Posted February 7, 2024 Hi all I've just finished a cbr that was crashed last year and have got a night mare of a charging problem going on basically stator was burnt out and flywheel magnets where weak so replaced flywheel and stator + battery and reg rec for good measure and all was good for about 80 miles and then flat battery so tested again and it's showing battery is charging when I take it up to 5-6k revs then suddenly drops to whatever the batter charge is at I've just tried another reg rec so convinced its not that checked stator with multimeter and all seems OK there aswell Quote
Guest Posted February 18, 2024 Posted February 18, 2024 well, it seems everyone and their granny is having the same issue, Honda acknowledged the fault and did a recall on some years don't know which year's thou. seem to be a design fault, you have changed the hole charging system, only thing I can think of is a duff battery. I see you have changed battery, do you have something else you try the battery on? Quote
