The 2024 Harley-Davidson Sportster S.
The 2024 Harley-Davidson Sportster S. (Harley-Davidson/)
When Harley-Davidson introduced the Sportster S in 2021, it practically took six decades of Sportster heritage and threw it out the window. In place of the familiar 1200 Evo mill, the Sportster S uses the Revolution Max 1250T engine, featuring a 60-degree V angle, liquid-cooling, four valves per cylinder, variable valve timing, crankpins with a 30-degree offset, and maintenance-free hydraulic lash valve adjusters. Producing a claimed 121 hp at 7,500 rpm and 93 lb.-ft. of torque at 6,000 rpm, the Revolution Max 1250T is a modern performance-oriented engine by most any estimation. Fully adjustable suspension, IMU-managed rider aids, and Brembo brakes take the Sportster experience to whole new heights.
Ultimately, is the Sportster S still a Sportster? Well, it’s still a cruiser. A modern cruiser, yes, but with a paltry 2 inches of rear travel and trad-cruiser geometry and ergos, sporting performance in the twisties hits a ceiling dictated by styling. So while the engine wants to rip, and you’ve got a safety net of zeros and ones in your right hand, you’ve gotta respect the bike’s inherent shortcomings. Nevertheless, the Sportster S shows that Harley-Davidson is willing to break the mold even at the expense of one of its most iconic names. With modern tech and performance, the Sportster S spearheads H-D’s performance-oriented vision. We can’t wait to see where it leads.
The Revolution Max 1250T engine is super torquey and refined. Maintenance-free hydraulic lash valve adjusters are a huge benefit for owners, lowering maintenance costs over the long term.
The Revolution Max 1250T engine is super torquey and refined. Maintenance-free hydraulic lash valve adjusters are a huge benefit for owners, lowering maintenance costs over the long term. (Harley-Davidson/)
The 2024 Sportster S starts at $16,999 and goes up based on color choice.
The round TFT dash fits the style of the bike and makes it far easier to navigate menus than a more traditional LCD setup would.
The round TFT dash fits the style of the bike and makes it far easier to navigate menus than a more traditional LCD setup would. (Harley-Davidson/)
  • <a href="https://www.cycleworld.com/motorcycle-reviews/triumph-rocket-3-storm-r-and-gt-first-ride-review/"><b>Triumph Rocket 3 Storm R</b></a>, $24,995
  • <a href="https://www.cycleworld.com/motorcycle-reviews/ducati-diavel-v4-first-ride-review-2023/"><b>Ducati Diavel V4</b></a>, $26,995
News and Reviews
  • <a href="https://www.cycleworld.com/story/motorcycle-reviews/2021-harley-davidson-sportster-s-first-ride-review/"><b>The 2021 Harley-Davidson Sportster S Is a Symbol of Change</b></a>
  • <a href="https://www.cycleworld.com/motorcycle-reviews/harley-davidson-sportster-s-review/"><b>The 2023 Harley-Davidson Sportster S Review</b></a>
2024 Harley-Davidson Sportster S Claimed Specs
MSRP: $16,999
Engine: DOHC, liquid-cooled, 60-degree V-twin w/ variable valve timing; 4 valves/cyl.
Engine: 76.4ci (1,252cc)
Bore x Stroke: 105.0 x 72.3mm
Compression Ratio: 12.0:1
Fuel System: EFI w/ 50mm throttle bodies, ride-by-wire
Clutch: Wet, multiplate assist and slip
Frame: Steel trellis w/ stamped, cast, and forged junctions, and forged aluminum mid-structure
Front Suspension: Fully adjustable Showa 43mm inverted fork; 3.6 in. travel
Rear Suspension: Fully adjustable Showa monoshock; 2.0 in. travel
Front Brake: Radially mounted Brembo Monoblock 4-piston caliper, 320mm disc w/ Cornering ABS
Rear Brake: Brembo 1-piston floating caliper, 260mm disc w/ Cornering ABS
Wheels, Front/Rear: Cast aluminum; 17 x 4.5 in. / 16 x 5.0 in.
Tires, Front/Rear: Dunlop Harley-Davidson Series Radials; 160/70R-17 / 180/70R-16
Rake/Trail: 30.0°/5.8 in.
Wheelbase: 59.8 in.
Ground Clearance: 3.5 in.
Seat Height: 30.1 in.
Fuel Capacity: 3.1 gal.
Wet Weight: 502 lb.
Contact: harley-davidson.com
The Billiard Gray color.
The Billiard Gray color. (Harley-Davidson/)One could argue ergos are sacrificed on the altar of style. Feet-forward controls and a longish reach to the bars make it difficult to ride with the sporting focus that the engine encourages.
One could argue ergos are sacrificed on the altar of style. Feet-forward controls and a longish reach to the bars make it difficult to ride with the sporting focus that the engine encourages. (Harley-Davidson/)The Sportster S in Vivid Black, which adds $300 to the base price.
The Sportster S in Vivid Black, which adds $300 to the base price. (Harley-Davidson/)
  • Thanks 1
  • Confused 1
