2024 Honda CBR1000R Black Edition.
2024 Honda CBR1000R Black Edition. (Honda/)
This isn’t just a sportbike stripped of its bodywork; the CB1000R Black Edition is a stylish interpretation of a naked sportbike with neo-retro design themes and a blacked-out appearance.
At its heart is a 998cc liquid-cooled inline-four engine that has been tuned for maximum torque between 6,000 to 8,000 rpm. The 44mm throttle bodies in the PGM-FI system are controlled by throttle-by-wire (TBW) allowing multiple ride modes including Rain, Standard, Sport, and a customizable User option. Other electronic features include: three levels of engine power, engine-brake control, and Honda Selectable Torque Control.
Chassis features include a steel backbone frame and signature single-sided swingarm. A fully adjustable Showa Separate Function Fork Big Piston unit (SFF-BP) and shock by the same make with preload and rebound damping handle suspension duty. A pair of radial-mount four-piston Tokico brake calipers and 310mm discs with standard ABS highlight the braking package.
2024 Honda CB1000R Black Edition Pricing and Variants
There is just one version of the CBR1000R Black Edition for $12,999.
  • <a href="https://www.cycleworld.com/story/motorcycle-reviews/2022-suzuki-gsx-s1000-first-ride/">Suzuki GSX-S1000, $11,699<br/> </a>
  • <a href="https://www.cycleworld.com/story/motorcycle-reviews/yamaha-mt-10-first-ride-2022/">Yamaha MT-10, $14,499<br/> </a>
  • <a href="https://www.cycleworld.com/story/buyers-guide/2022-bmw-s-1000-r/">BMW S 1000 R, $14,295 to $</a>20,685<br/>
  • <a href="https://www.cycleworld.com/story/bikes/triumph-announces-all-new-speed-triple-1200-rs/">Triumph Speed Triple 1200 RS, $18,895</a> to $19,220<br/>
  • <a href="https://www.cycleworld.com/motorcycle-reviews/hyper-naked-motorcycles-comparison-test-review-part-2-2023/">Aprilia Tuono V4 Factory 1100, $19,599<br/> </a>
  • <a href="https://www.cycleworld.com/ducati/streetfighter-v4-s-sp2-lamborghini/">Ducati Streetfighter V4, $22,095<br/> </a>
2024 Honda CB1000R Black Edition News and Reviews
  • <a href="https://www.cycleworld.com/story/motorcycle-reviews/honda-cb1000r-black-edition-2022-review/">2022 Honda CB1000R Black Edition<br/> </a>
2024 Honda CB1000R Black Edition Claimed Specs
MSRP: $12,999
Engine: DOHC, liquid-cooled inline-four; 4 valves/cyl.
Displacement: 998cc
Bore x Stroke: 75.0 x 56.5mm
Compression Ratio: 11.6:1
Fuel System: PGM-FI fuel injection w/ 44mm throttle bodies, throttle-by-wire
Clutch: Wet, multiplate
Frame: Steel backbone
Front Suspension: 43mm Showa SFF-BP fork, spring preload, rebound, and compression damping adjustable; 4.7 in. travel
Rear Suspension: Single Showa shock, spring preload and rebound damping adjustable; 5.2 in. travel
Front Brake: Dual radial-mounted 4-piston calipers, full-floating 310mm discs w/ ABS
Rear Brake: 2-piston caliper, 256mm disc w/ ABS
Tires, Front/Rear: 120/70-17 / 190/55-17
Rake/Trail: 24.7°/3.8 in.
Wheelbase: 57.3 in.
Ground Clearance: 5.3 in.
Seat Height: 32.7 in.
Fuel Capacity: 4.3 gal.
Wet Weight: 467 lb.
