The 2024 Harley-Davidson Road Glide Limited.As part of the Road Glide’s 2024 update, the fairing got a (shark)nose job. The updated look—and the rest of the updates—have yet to make their way to the Limited.The Limited’s 6-gallon tank. Note the analog gauges in the fairing, which were replaced as part of the 2024 update for its bagger sibling.Vivid Black costs an additional $750 over the base price.Generous upper and lower body weather protection for the rider and a plush passenger seat make the Goad Glide Limited about as comfortable as you can get on two wheels.The Sharkskin Blue color adds $1,000 to the base price.
The Harley-Davidson Road Glide Limited is the full-on touring version of the Road Glide bagger. In 2024, the Road Glide received a massive overhaul, but the Limited is yet to receive commensurate changes, though we’d imagine they’re coming very soon. For 2024, the Limited soldiers on as we’ve known it, with its frame-mounted sharknose fairing, a Twin-Cooled Milwaukee-Eight 114 engine, and a touchscreen Boom! Box GTS infotainment system. With a substantial 4.7 cubic feet (133 liters) of luggage capacity and exceptionally appointed rider and passenger accommodations, the Limited is designed for long-distance touring comfort—Milwaukee-style.
The 2024 Harley-Davidson Road Glide Limited. (Harley-Davidson/)
The Twin-Cooled Milwaukee-Eight 114 engine, which features liquid-cooled cylinder heads, produces a claimed 93 hp at 5,020 rpm and 122 lb.-ft. of torque at 2,750 rpm. ABS and linked braking are standard, but the Limited can be spec’d with lean-angle-sensitive ABS, traction control, and drag-torque slip control. Additional options include hill hold control and tire pressure monitoring. Surely, H-D touring fans await the updated Limited with bated breath, but for now, the 2024 model offers a ton of capability in the familiar style that many fans love.
As part of the Road Glide’s 2024 update, the fairing got a (shark)nose job. The updated look—and the rest of the updates—have yet to make their way to the Limited. (Harley-Davidson/)
2024 Harley-Davidson Road Glide Limited Pricing and Variants
The 2024 Road Glide Limited starts at $32,499. The price increases from between $750 and $1,800 depending on color.
The Limited’s 6-gallon tank. Note the analog gauges in the fairing, which were replaced as part of the 2024 update for its bagger sibling. (Harley-Davidson/)
  • <a href="https://www.cycleworld.com/honda/gold-wing/">Honda Gold Wing Tour, $28,700</a>, LINK<br/>
  • <a href="https://www.cycleworld.com/bikes/indian-roadmaster-elite-first-look/">Indian Roadmaster, $34,999</a>, Link<br/>
2024 Harley-Davidson Road Glide Limited News and Reviews
  • <a href="https://www.cycleworld.com/2020-harley-road-glide-limited-first-ride/">2020 Harley-Davidson Road Glide Limited First Ride<br/> </a>
2024 Harley-Davidson Road Glide Limited Claimed Specs
MSRP: Starting at $32,499
Engine: 45-degree V-twin; 4 valves/cyl., liquid-cooled heads
Displacement: 114ci (1,868cc)
Compression Ratio: 10.5:1
Clutch: Wet, multiplate
Frame: Tubular steel
Front Suspension: 49mm dual bending valve; 4.6 in. travel
Rear Suspension: Standard-height shock, preload adjustable; 3.0 in. travel
Front Brake: 4-piston caliper, 300mm discs
Rear Brake: 4-piston caliper, 300mm disc
Wheels, Front/Rear: Cast; 18 in./18 in.
Tires, Front/Rear: Dunlop Harley-Davidson Series; 130/70-18 / 180/55-18
Rake/Trail: 26.0°/6.7 in.
Wheelbase: 64.0 in.
Ground Clearance: 5.1 in.
Seat Height: 28.9 in.
Fuel Capacity: 6.0 gal.
Wet Weight: 932 lb.
Contact: harley-davidson.com
Vivid Black costs an additional $750 over the base price. (Harley-Davidson/)Generous upper and lower body weather protection for the rider and a plush passenger seat make the Goad Glide Limited about as comfortable as you can get on two wheels.
Generous upper and lower body weather protection for the rider and a plush passenger seat make the Goad Glide Limited about as comfortable as you can get on two wheels. (Harley-Davidson/)The Sharkskin Blue color adds $1,000 to the base price.
The Sharkskin Blue color adds $1,000 to the base price. (Harley-Davidson/)
