Admin Posted July 27, 2024 Posted July 27, 2024 2024 Honda NX500. (Honda/)OverviewAs far back as the late 1980s, the letters “NX” have represented adventure, meaning New X-over (crossover). For 2024, Honda has renamed the CB500X and changed it to NX500. But the bike gets a lot more than just a name change. Overall weight is down by 7 pounds, dropping from 439 to 432, while the new cast-aluminum wheels have saved 3.3 pounds of unsprung weight alone. Other additions include standard Honda Selectable Torque Control, ECU updates for improved acceleration, new suspension settings, a new 5-inch TFT display, and new LED headlight.At its core is a liquid-cooled 471cc parallel-twin engine that has been tuned for low- to midrange torque between 3,000 and 7,000 rpm. The engine is fed by PGM-FI fuel injection and as mentioned now comes standard with Honda’s Selectable Torque Control (traction control).Chassis highlights include the suspension that utilizes a 41mm Showa Separate Function Fork Big Piston (SFF-BP) fork with 5.2 inches of travel, and preload-adjustable Showa shock with 5.3 inches of travel. Wheelbase measures 56.8 inches, while the seat height has been kept at a reasonable 32.8 inches. A pair of Nissin two-piston calipers and 296mm discs and a single-piston caliper and 240mm disc take care of braking, and ABS is standard. The new lighter cast-aluminum wheels have Y-shaped spokes and are mounted with 110/80-19 front and 160/60-17 rear rubber.2024 Honda NX500. (Honda/)2024 Honda NX500 Pricing and VariantsThe 2024 Honda NX500 is available in Matte Black Metallic for $7,399.2024 Honda NX500 in Matte Black Metallic. (Honda/)Competition<a href="https://www.cycleworld.com/story/buyers-guide/triumph-tiger-sport-660-2022/">Triumph Tiger 660 Sport, $9,695<br/> </a><a href="https://www.cycleworld.com/motorcycle-reviews/yamaha-tenere-700-first-ride-review/">Yamaha Ténéré 700, $10,799<br/> </a><a href="https://www.cycleworld.com/motorcycle-reviews/kawasaki-klr650-s-first-ride-review-2023/">Kawasaki KLR650, starting at $6,899<br/> </a><a href="https://www.cycleworld.com/story/buyers-guide/suzuki-v-strom-650-xt-adventure-2023/">Suzuki V-Strom 650, $9,199<br/> </a><a href="https://www.cycleworld.com/story/buyers-guide/2020-ktm-790-adventureadventure-r/">KTM 790 Adventure, $10,990<br/> </a><a href="https://www.cycleworld.com/story/bikes/2021-bmw-f-750-gs-f-850-gs-and-f-850-gs-adventure-released/">BMW F 750 GS, starting at $9,995<br/> </a>2024 Honda NX500 News and Reviews<a href="https://www.cycleworld.com/motorcycle-news/honda-updates-cb500-series-for-2024/">Honda Updates CB500 Lineup<br/> </a><a href="https://www.cycleworld.com/bikes/honda-cb500-hornet-nx500-and-cbr500r/">NX500 First Look<br/> </a>2024 Honda NX500 Claimed Specs MSRP: $7,399 Engine: DOHC, liquid-cooled parallel twin; 4 valve/cyl. Displacement: 471cc Bore x Stroke: 67.0 x 66.8mm Compression Ratio: 10.7:1 Transmission/Final Drive: 6-speed/chain Fuel System: PGM-FI fuel injection w/ 34mm throttle bodies Clutch: Wet, multiplate; cable operation Frame: Steel diamond Front Suspension: 41mm Showa SFF-BP fork; 5.2 in. travel Rear Suspension: Pro-Link single shock, preload adjustable; 5.3 in. travel Front Brake: 2-piston calipers, 296mm discs w/ ABS Rear Brake: 1-piston caliper, 240mm disc w/ ABS Wheels, Front/Rear: Cast aluminum; 19 in./17 in. Tires, Front/Rear: 110/80-19 / 160/60-17 Rake/Trail: 27.0°/4.3 in. Wheelbase: 56.8 in. Ground Clearance: 7.1 in. Seat Height: 32.8 in. Fuel Capacity: 4.7 gal. Wet Weight: 432 lb. Contact: powersports.honda.com View the full article Quote
