Royal Enfield’s Guerrilla 450 is powered by the 452cc liquid-cooled Sherpa engine.
Royal Enfield’s Guerrilla 450 is powered by the 452cc liquid-cooled Sherpa engine. (Royal Enfield/)The Guerrilla 450 is Royal Enfield’s second liquid-cooled model ever.
The Guerrilla 450 is Royal Enfield’s second liquid-cooled model ever. (Royal Enfield/)A 84.0 x 81.4mm bore and stroke gives the Sherpa engine a displacement of 452cc.
A 84.0 x 81.4mm bore and stroke gives the Sherpa engine a displacement of 452cc. (Royal Enfield/)While the frame is similar to the Himalayan, the Guerrilla has its own unique chassis.
While the frame is similar to the Himalayan, the Guerrilla has its own unique chassis. (Royal Enfield/)A nonadjustable 43mm Showa fork is one half of the Guerrilla 450′s suspension; the other is a preload-adjustable rear monoshock.
A nonadjustable 43mm Showa fork is one half of the Guerrilla 450′s suspension; the other is a preload-adjustable rear monoshock. (Royal Enfield/)The dash on the base-model Guerrilla is an analog unit with an LCD info screen; the Tripper module on the left is standard equipment.
The dash on the base-model Guerrilla is an analog unit with an LCD info screen; the Tripper module on the left is standard equipment. (Royal Enfield/)The 4-inch TFT dash on the Guerrilla 450 has multiple layouts, including a navigation screen powered by Google via the Royal Enfield app.
The 4-inch TFT dash on the Guerrilla 450 has multiple layouts, including a navigation screen powered by Google via the Royal Enfield app. (Royal Enfield/)Rowing through the gears on the Guerrilla 450 is a blast as you scoot from one corner to the next.
Rowing through the gears on the Guerrilla 450 is a blast as you scoot from one corner to the next. (Royal Enfield/)A 2.9-gallon fuel tank is claimed to give a 180-mile range. We found it to be a bit less than that but more testing back in the States will give us real numbers.
A 2.9-gallon fuel tank is claimed to give a 180-mile range. We found it to be a bit less than that but more testing back in the States will give us real numbers. (Royal Enfield/)Royal Enfield’s Guerrilla handles well—both in the twisty mountain roads and the city.
Royal Enfield’s Guerrilla handles well—both in the twisty mountain roads and the city. (Royal Enfield/)Grip from the Ceat tires is excellent.
Grip from the Ceat tires is excellent. (Royal Enfield/)Braking power is excellent from the seemingly low-spec ByBre brakes.
Braking power is excellent from the seemingly low-spec ByBre brakes. (Royal Enfield/)The Guerrilla’s seat doesn’t offer much room to move around but it is very comfortable.
The Guerrilla’s seat doesn’t offer much room to move around but it is very comfortable. (Royal Enfield/)European pricing has the base-model Guerrilla 450 (shown) at 5,290 euros, no word on US pricing.
European pricing has the base-model Guerrilla 450 (shown) at 5,290 euros, no word on US pricing. (Royal Enfield/)There are five color choices for the 2025 Guerrilla 450. From left to right: Yellow Ribbon, Brava Blue, Playa Black, Smoke Silver, and Gold Dip.
There are five color choices for the 2025 Guerrilla 450. From left to right: Yellow Ribbon, Brava Blue, Playa Black, Smoke Silver, and Gold Dip. (Royal Enfield/)Corner stability is impressive on the Guerrilla 450.
Corner stability is impressive on the Guerrilla 450. (Royal Enfield/)Royal Enfield has a load of accessories ready to go for the Guerrilla 450, including a tall seat.
Royal Enfield has a load of accessories ready to go for the Guerrilla 450, including a tall seat. (Royal Enfield/)An LED headlight is standard on the Guerrilla 450.
An LED headlight is standard on the Guerrilla 450. (Royal Enfield/)A preload-adjustable monoshock provides 5.9 inches of rear wheel travel.
A preload-adjustable monoshock provides 5.9 inches of rear wheel travel. (Royal Enfield/)Royal Enfield’s Guerrilla 450 feels lighter than its claimed 408-pound wet weight.
Royal Enfield’s Guerrilla 450 feels lighter than its claimed 408-pound wet weight. (Royal Enfield/)
