2024 Honda PCX.
2024 Honda PCX. (Honda/)
If navigating the urban jungle is the goal, the PCX was designed to excel in that environment. It’s comfortable, has enough power for the highway, and packs plenty of underseat storage and an additional front storage compartment.
The PCX is powered by a 157cc single-cylinder engine with fuel injection for reliable and efficient power delivery. Power is sent to a low-friction Honda V-Matic automatic transmission for easy gas-it-and-go simplicity.
A 31mm telescopic fork with 3.9-inch travel, and a pair of twin rear shocks with 3.7 inches of travel handle suspension duty while cast aluminum wheels in 14-inch front and 13-inch rear are mounted with 110/70-14 front and 130/70-13 rear tires. ABS and Honda Selectable Torque Control (HSTC) come standard.
The 2024 Honda PCX is available in Matte Brown Metallic for $4,249.
  • <a href="https://www.cycleworld.com/story/buyers-guide/2020-yamaha-xmax/"><b>Yamaha XMAX, $6,199</b></a>
  • <a href="https://www.cycleworld.com/tags/burgman-200/"><b>Suzuki Burgman 200, $4,999</b></a>
  • <a href="https://www.cycleworld.com/bikes/vespa-primavera-and-sprint-s-first-look/"><b>Vespa Primavera 150, starting at $5,749</b></a>
  • Piaggio Liberty 150, $3,199
News and Reviews
  • <a href="https://www.cycleworld.com/story/bikes/2021-honda-pcx-first-look/"><b>Honda PCX First Look</b></a>
2024 Honda PCX Claimed Specs
MSRP: $4,249
Engine: OHC, liquid-cooled single; 4 valves
Displacement: 157cc
Bore x Stroke: 60.0 x 55.5mm
Compression Ratio: 12.0:1
Transmission/Final Drive: V-Matic/belt
Fuel System: PGM-FI w/ 28mm throttle body
Clutch: Automatic centrifugal dry type
Frame: Steel tube
Front Suspension: 31mm telescopic fork; 3.9 in. travel
Rear Suspension: Twin shocks; 3.7 in. travel
Front Brake: Hydraulic caliper, 220mm disc w/ ABS
Rear Brake: Mechanical w/ 130mm drum w/ ABS
Wheels, Front/Rear: Cast aluminum; 14 in./13 in.
Tires, Front/Rear: 110/70-14 / 130/70-13
Rake/Trail: 26.5°/3.1 in.
Wheelbase: 51.7 in.
Ground Clearance: 5.3 in.
Seat Height: 30.1 in.
Fuel Capacity: 2.1 gal.
Wet Weight: 286 lb.
