Admin Posted August 2, 2024 Posted August 2, 2024 2024 Honda Shadow Aero. (Honda/) Overview Honda’s Shadow Aero is a classically styled metric cruiser with a fully modern powertrain. For 2024 it received a disc brake at the rear, which was previously only available on the ABS version. Buyers will still have to choose between the non-ABS or ABS model (California buyers can only buy the ABS version). The two-tone paint is also new for 2024. Power comes from a liquid-cooled 745cc V-twin that produces good low-down torque. Programmed Fuel Injection ensures excellent response and efficacy. The Aero uses a five-speed transmission and sends power to a low-maintenance shaft final drive. An ultralow 26-inch seat means a wide range of riders can get their feet firmly down at stops or maneuvering in parking lots. Pricing and Variants The 2024 Honda Shadow Aero is available in one color, which Honda calls black but is really a two-tone fade on the tank and side covers. The non-ABS version is set at $7,949, while the ABS model is $8,249. Competition <a href="https://www.cycleworld.com/story/buyers-guide/2020-yamaha-bolt-r-spec/"><b>Yamaha Bolt R Spec, $8,899</b></a> <b>2025 </b><a href="https://www.cycleworld.com/story/buyers-guide/2020-suzuki-boulevard-c50t/"><b>Suzuki Boulevard C50, $9,299</b></a> <a href="https://www.cycleworld.com/story/buyers-guide/2020-kawasaki-vulcan-900-classic-lt/"><b>Kawasaki Vulcan 900 Classic, starting at $9,399</b></a> 2024 Honda Shadow Aero / Shadow Aero ABS Claimed Specs MSRP: $7,949 / $8,249 (ABS) Engine: SOHC, liquid-cooled V-twin; 3 valves/cyl. Displacement: 745cc Bore x Stroke: 79.0 x 76.0mm Compression Ratio: 9.6:1 Transmission/Final Drive: 5-speed/shaft Fuel System: PGM-FI w/ 34mm throttle body Clutch: Wet, multiplate Frame: Steel Front Suspension: 41mm telescopic fork; 5.5 in. travel Rear Suspension: Dual shocks, preload adjustable; 3.6 in. travel Front Brake: 2-piston caliper, 296mm disc (w/ ABS) Rear Brake: 1-piston caliper, 276mm disc (w/ ABS) Wheels, Front/Rear: Spoked; 17 in./15 in. Tires, Front/Rear: 120/90-17 / 160/80-15 Rake/Trail: 34.0º/6.3 in. Wheelbase: 64.6 in. Ground Clearance: 5.1 in. Seat Height: 26.0 in. Fuel Capacity: 3.9 gal. Wet Weight: 560 lb. / 570 lb. (ABS) Contact: powersports.honda.com View the full article Quote
