2024 Kawasaki Ninja 500 in Metallic Spark Black/Metallic Flat Raw Graystone.
2024 Kawasaki Ninja 500 in Metallic Spark Black/Metallic Flat Raw Graystone. (Kawasaki/)
Kawasaki’s Ninja 500 sportbike offers the same accessibility as the Ninja 400 but with a larger engine. For 2024, Kawasaki bumped up the engine displacement of its tried-and-true 399cc mill to 451cc by increasing the stroke by 8.6mm. Along with the larger engine, the Ninja 500 also receives updated styling and a new dash—other than that, the Ninja 500 is extremely similar to the Ninja 400.
The 2024 Kawasaki Ninja 500 features a 451cc DOHC liquid-cooled parallel twin making a claimed 51 hp at 10,000 rpm and 31.7 lb.-ft. of torque at 7,500 rpm. Bore measurement remains the same as the 400 at 70.0mm, but this larger engine (utilized in the Ninja 500, Z500, and Eliminator) now features a 58.6mm stroke.
At its core, the Ninja 500 chassis is the Ninja 400 chassis. The 500 utilizes the same steel-trellis frame, 41mm telescopic fork, horizontal back-link shock, and braking system with a dual-piston caliper and 310mm rotor up front and a single 220mm rotor and single-piston caliper at the rear.
The 2024 Kawasaki Ninja 500 receives an updated LCD display. But for those who want even more premium features, check out the 2024 Kawasaki Ninja 500 SE ABS which features a full-color TFT display with a range of Kawasaki Genuine Accessories including special-edition graphics, Intelligent Proximity Activation Start System, LED turn signals, large windshield, pillion seat cover, frame sliders, USB-C outlet, tank pad, knee pads, radiator screen.
2024 Kawasaki Ninja 500 KRT Edition SE ABS.
2024 Kawasaki Ninja 500 KRT Edition SE ABS. (Kawasaki/)
The 2024 Kawasaki Ninja 500 is available in five variants: Ninja 500 non-ABS ($5,299) and Ninja 500 ABS ($5,699–$5,899); Ninja 500 KRT Edition ($5,499); Ninja 500 SE ABS ($6,399); Ninja 500 KRT Edition SE ABS ($6,399); Ninja 500 SE 40th Anniversary Edition ABS ($6,599).
2024 Kawasaki Ninja 500 SE 40th Anniversary Edition ABS.
2024 Kawasaki Ninja 500 SE 40th Anniversary Edition ABS. (Kawasaki/)
  • <a href="https://www.cycleworld.com/story/motorcycle-reviews/honda-cbr500r-abs-cb500f-abs-review-2022/"><b>Honda CBR500R, $7,399</b></a>
  • <a href="https://www.cycleworld.com/story/motorcycle-reviews/2022-ktm-rc-390-track-test/"><b>KTM RC 390, $5,899</b></a>
News and Reviews
  • <a href="https://www.cycleworld.com/motorcycle-reviews/kawasaki-ninja-500-first-ride-review/"><b>2024 Kawasaki Ninja 500 First Ride Review&nbsp;</b></a>
  • <a href="https://www.cycleworld.com/bikes/kawasaki-ninja-500-first-look/"><b>2024 Kawasaki Ninja 500 First Look</b></a>
  • <a href="https://www.cycleworld.com/bikes/kawasaki-eliminator-se-dyno-test-2024/"><b>How Much Power Does the 2024 Kawasaki Eliminator SE Make?</b></a>
2024 Kawasaki Ninja 500 Claimed Specs
MSRP: $5,299 / $5,699–$5,899 (ABS)
Engine: DOHC, liquid-cooled, 4-stroke parallel twin
Displacement: 451cc
Bore x Stroke: 70.0 x 58.6mm
Compression Ratio: 11.3:1
Fuel System: DFI w/ dual 32mm throttle bodies
Frame: Trellis, high-tensile steel
Front Suspension: 41mm hydraulic telescopic fork; 4.7 in. travel
Rear Suspension: Horizontal back-link shock, preload adjustable; 5.1 in. travel
Front Brake: 2-piston calipers, 310mm disc (w/ ABS)
Rear Brake: 1-piston caliper, 220mm disc (w/ ABS)
Wheels, Front/Rear: Cast spoked; 17 in./17 in.
Rake/Trail: 24.5°/3.6 in.
Wheelbase: 54.1 in.
Ground Clearance: 5.7 in.
Seat Height: 30.9 in.
Fuel Capacity: 3.7 gal.
Wet Weight: 370 lb. / 375 lb. (ABS)
Contact: kawasaki.com
